cluster........
Old Jul 28, 2014 | 02:51 PM
jbclutch's Avatar
jbclutch
St. Jude Donor '09-'12
Default cluster........
Queston, want to put HUD on my 99 FRC...I also want to install a Z06 cluster...Now, will I have any trouble with the cluster? Is it plug and play? Thanks..........
Old Jul 28, 2014 | 02:53 PM
sfc rick's Avatar
sfc rick
Plug and Play
Old Jul 28, 2014 | 03:00 PM
Pirateslife4me's Avatar
Pirateslife4me
I had to change the placement of bulb for the airbag light when I updated my 98 to a HUD cluster other than that it all just pretty much pops into place.
Old Jul 28, 2014 | 03:26 PM
Maxx_Z06's Avatar
Maxx_Z06
C5 COTM Coordinator
Since we're on the subject once you install a different cluster can the exact mileage of the car be updated on the new one?
Old Jul 28, 2014 | 04:22 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
There was a member on here few years back that did that if you were buying a HUD compatible cluster from him. He sold the kits for the HUD installs. So yes it can be done, but who does it now, I don't know.
I suppose the dealer can if this guy could.
Old Jul 28, 2014 | 04:28 PM
Maxx_Z06's Avatar
Maxx_Z06
C5 COTM Coordinator
I'm sorry i completely disregarded what you wrote because your avatar is extremely distracting jk.
Good info, just curious.
Old Jul 28, 2014 | 05:33 PM
jamieo's Avatar
jamieo
You can keep the correct mileage by swapping the circuit boards out.Takes about 15 minutes to do once your cluster is out
Old Jul 28, 2014 | 06:36 PM
zagger's Avatar
zagger
Correct me if I'm wrong but if your old board did not have the pin-out for the cluster you will not be able to swap it out and maintain the HUD?
Old Jul 28, 2014 | 06:43 PM
GCG's Avatar
GCG
The mileage information is stored in the IPC's main board, so yes, swapping main boards to keep your old one in your new IPC will allow you keep your correct mileage.
Problem is if you are replacing a non-HUD IPC with a HUD-enabled IPC with the intention of adding HUD to a car that didn't have it. This is because the IPC's HUD connector is also on the main board. In this case the only way out is to have the new IPC reprogrammed with the correct mileage.
Sent from my DROID RAZR using IB AutoGroup
Old Jul 29, 2014 | 10:39 AM
jbclutch's Avatar
jbclutch
I did buy a used HUD,and switch, wirring...Now would like to put a z06 cluster in with my HUD...Hope this will be plug and play..
Old Jul 30, 2014 | 01:43 AM
GCG's Avatar
GCG
Check post #3 above. Pirateslife4me is telling you he had to change the location of the air bag light, but everything else was plug-and-play.
Your car is a 99 and your new IPC is from a Z06. His is a 98 and he doesn't mention the origin of his new IPC. I don't know if that would make a difference.
Old Jul 30, 2014 | 09:30 AM
LoneStarFRC's Avatar
LoneStarFRC
Originally Posted by sfc rick
Plug and Play
Mileage will be different as mentioned.
You mention "wiring" on your list of parts. This MUST be the correct 11-pin connector cable.
Old Jul 30, 2014 | 10:05 AM
jbclutch's Avatar
jbclutch
yes it came with the HUD unit..so did the switch..
Old Jul 30, 2014 | 05:36 PM
LoneStarFRC
Great. Just get a bezel, remove dash pad and start cutting. Take your time and keep track of every fastener along the way. Use a camera if you have to.
Come time to mount the projector, I used a Well nut after drilling the one hole you need for mounting. Couldn't get a drill in there due to the slant of the windshield so I used a Dremel with a right-angle head on it to drill a starter hole. Then I just used a tapered reamer to enlarge it to the correct size for the Well nut.
Old Aug 2, 2014 | 04:39 PM
jbclutch's Avatar
jbclutch
Thank you for the help...Have some parts, still looking for A Z06, C5, HUD Cluster..
Old Aug 2, 2014 | 08:19 PM
LoneStarFRC
Just so you know, ALL Z06 cars had HUD-enabled clusters, so just locate any Z06 IPC cluster you like, and you're good.
Might help in your searching.
Old Aug 6, 2014 | 02:17 PM
jbclutch's Avatar
jbclutch
Many Thanks....
To cluster........
