Just like the title says I weighed my Z06. Its an 02, with Texas Speed longtubes and catless x-pipe, and a Blackwing intake. Otherwise it was completely stock. 3,020 lbs.
Looks like you have heavy wheels to start... Going by your avatar... What's your set up?
I have a bunch of little stuff that adds up.
Wheels/tires are 49 lbs each front and 59 lbs each rear.
C6 Z51 rotors are bigger and heavier than stock, not sure how much.
Corsa exhaust and x-pipe are heavier than stock Ti
Ron Davis radiator with engine and trans oil coolers add weight plus the pump for the trans cooler, all of the lines, and the extra fluids
The custom paint probably adds 5-10 lbs too
I'm not surprised to be significantly heavier than stock, but I wasn't expecting 150 lbs. I'd always seen the stock weight listed as 3118.
last time I weighed mine it was 3150lbs with me in it and a half tank of gas... I had heavier exhaust and tires (rims weighed about the same as stock wheels)... since then I have added c6z brakes and a blower kit so maybe another 150lbs but still lighter than most other comparable cars and with a lot of power
Me in it. full tank of gas. 18 x 10.5 chrome z06 knockoffs with pilot sports. Assorted cans of wax and window cleaner and rags. Tire compressor. My laptop bag. 3400 exactly to the pound.
3020 wow! I'm surprised. I'm skeptical about whether the local truck/ dump scale is all that accurate.
Measured on my Longacre corner weighting scales, mine weighs 3130 without me in it, 1/2 tank of fuel, harness bar, race seat, LG longtubes, no cats, stock Ti, and 17x11 / 17x12 CCW Classics.
Thanks...I'm hoping it will go 8.90s in winter air...
Its a porker for sure.. And that's on my light wheels (CCWs)
When its on the stock chrome speedlines with 275/305s its another 60lbs heavier.. So 3660lbs in street trim.
A few months after I weighed it on the CAT scales, I weighed it at the drag strip with in full street trim with a little more fuel and it was 3670lbs... So pretty consistent with the CAT scale.
I really which I could lighten it back up but......
