New Front Splitter Causing Overheating?
Old Jul 31, 2014 | 05:34 PM
Monkey D. Luffy's Avatar
Monkey D. Luffy
Default New Front Splitter Causing Overheating?
I just installed a ZR1 style front splitter. Drove the car less than 2 miles and the temperature went up to 240!
Has anybody else had this problem? is this the front splitter or just something else coincidentally puking out on me at this time? I checked and both radiator fans were working.
Old Jul 31, 2014 | 05:52 PM
Check that the area in front of the radiator is clear of debris too. Since the C5 breathes from the bottom, if that area gets clogged up the temps will rise.
Old Jul 31, 2014 | 05:54 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I can't see the splitter doing that.
Old Jul 31, 2014 | 05:59 PM
hawk4077's Avatar
hawk4077
You didn't by chance take the center air dam out from under the front end did you?
Monkey D. Luffy
I have been thinking the same thing. No debris... just put splitter on. It shouldn't have gotten that hot that fast. Thinking there is something else going on and just coincidence that it happened when new splitter was installed.
Thanks Mr. Bill and Vetteman Jack
Old Jul 31, 2014 | 06:01 PM
Monkey D. Luffy
Center dam still there.
Old Jul 31, 2014 | 06:08 PM
Mr.Bill's Avatar
Mr.Bill
Did you change the antifreeze? Maybe you need to burp the system?
Old Jul 31, 2014 | 06:30 PM
Monkey D. Luffy
Nope, it was about this time last year when I changed it
Old Jul 31, 2014 | 06:39 PM
scarecrowkc5's Avatar
scarecrowkc5
How did you check the fans?
Old Jul 31, 2014 | 06:40 PM
hawk4077's Avatar
hawk4077
Sounds like something out of place, or overlooked very strange to have happened suddenly like that.
Old Jul 31, 2014 | 07:10 PM
RFDrpm's Avatar
RFDrpm
Which splitter did you install?
Does the front splitter cover the area under the radiator?
I know some of them have cutouts to allow air up in the radiator and some don't.
Old Jul 31, 2014 | 09:02 PM
c5vetteguy's Avatar
c5vetteguy
2018 C5 of Year Finalist
Got a picture of said splitter?
If it's the kind that has no center vent/duct, that's your problem.
Old Jul 31, 2014 | 10:31 PM
95wht6spd's Avatar
95wht6spd
I have seen a number of threads where the splitter has caused a heat increase.
Old Aug 1, 2014 | 11:06 AM
Monkey D. Luffy
Yes, but it does have cut outs, however the cutouts where small. I'm going to make the cutouts bigger and see if that helps
Old Aug 1, 2014 | 11:07 AM
Monkey D. Luffy
I'll try and post up Pics of the splitter this weekend
Old Aug 1, 2014 | 11:25 AM
c5vetteguy's Avatar
c5vetteguy
It sounds like you have the one with the small cutouts towards the outside and a solid "dam" in the center. Not a good design for the C5, as the C5 is a bottom breather. The C6s can get away with that style splitter as they're front breathers.
Your splitter is blocking the air flow to the center stock scoop (that hinged, plastic thing that hangs down and scrapes on everything). That scoop directs air up to the radiator, but you're negating its function with that type of splitter. You could have your fans programmed to come on at a lower temperature, but that's just a band-aid and not a fix.
Old Aug 1, 2014 | 11:46 AM
Monkey D. Luffy
To New Front Splitter Causing Overheating?
Old Aug 1, 2014 | 05:09 PM
Monkey D. Luffy
Thanks to everybody that replied !! making the cutouts bigger worked. car is now running 198 in traffic with A/C on in the Georgia heat.
Old Aug 1, 2014 | 06:12 PM
RFDrpm's Avatar
RFDrpm
Old Aug 1, 2014 | 07:18 PM
Glad you got it figured out. Perhaps it would be a good idea to let the vendor for the splitter know what problems you had and maybe they can adjust the manufacturing process so it doesn't happen to someone else.
