Interior lights stay on
Old Aug 5, 2014 | 09:06 AM
uncle wilson's Avatar
uncle wilson
Default Interior lights stay on
Interior lights stay on is thier a fuse I can pull? What do I need to do?
Old Aug 5, 2014 | 09:38 AM
Phanni's Avatar
Phanni
The light should remain on for about 5 minutes.
If it stay longer than that, you've got a problem that will drain the battery.
Old Aug 5, 2014 | 10:24 AM
uncle wilson
Battery draining thought it was the ignition switch changed it ! Is there a fuse?
Old Aug 12, 2014 | 03:38 PM
uncle wilson
Ok was the tiny interior light button! ???
Old Aug 12, 2014 | 10:42 PM
SG Lou's Avatar
SG Lou
That will do it
Old Aug 12, 2014 | 10:57 PM
65GGvert's Avatar
65GGvert
Just checking for the record, you changed the ignition switch and the problem was the interior lights were turned on with the dash dimmer switch? Not meant to criticize, I just want to make sure I get the correct picture.
Old Aug 13, 2014 | 08:36 AM
uncle wilson
Ok correct only have had this car since 05 !!never have used the switch!
Old Aug 13, 2014 | 01:54 PM
C5Txfan's Avatar
C5Txfan
Originally Posted by 8VETTE7
Somebody did. Knowingly or otherwise. It can't turn itself past the click to lock the interior lights on.
Maybe it got turned during a detailing ?? They're kinda hard to turn when pushed all the way in.
To Interior lights stay on
By Michael S. Palmer | 2026-06-03 11:00:24
