Turn Singal
Old Aug 6, 2014 | 08:56 AM
Donald1's Avatar
Donald1
Cruising
Default Turn Singal
I have a 2000 Corvette. My directional do not work from time to time. To fix this I have to put on my flashers and sometimes my head lights to make them work. And they come back on. What is that all about! Can anyone have any idea.
Old Aug 6, 2014 | 10:07 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Your 4 way flasher switch is going out, The Turn signals go thru the 4 way switch, It is a pain to replace the switch, Here is an easy fix.
http://shop.jwmotoring.com/C5-LED-Hy...ashHarness.htm
Old Aug 6, 2014 | 11:56 AM
65GGvert's Avatar
65GGvert
If you Google "C5 turn signal fix" you'll see multiple responses with pictures and videos of how to replace or bypass your hazard switch.
Old Aug 6, 2014 | 12:16 PM
Nate@VanBortelChevy's Avatar
Nate@VanBortelChevy
Platinum Supporting Dealership
Yup, sounds like the hazard/flasher switch is going bad. You don't have to remove the upper dash panel, but it is a tight fit, remove the radio and loosen the IPC upper screws and you can squeeze it out.
To Turn Singal
