Glove Box Latch Broken
Old Aug 10, 2014 | 07:26 PM
Frankie 69's Avatar
Frankie 69
8th Gear
Default Glove Box Latch Broken
My glove box latch on my 2002 Vette fell apart into 2 pieces. It is apparently a common problem. The tips of the plastic pylons break off and release the long rivet that holds the 2 halves together. I made a temporary repair until I can find a bargain source for a new one. I used some thin thermostat wire to bind together the 2 halves (I wrapped the wire around the rivet, drilled a small hole in the other half and inserted the wire thru it, and bound the 2 halves together with the wire). I strengthened the contact between the rivet and the ends of the pylons with some WELD putty. Does anyone have a good source for a new latch?
Old Aug 10, 2014 | 10:57 PM
Not sure if you have to buy a new glove box lid just to get the latch, but worth a call to a place like gmpartshouse.com to see if the latch is sold separately. If not, try one of the used parts vendors here on the forum. Just remember that you wouldn't be able to use your key to lock the glove box unless you can get the new latch re-keyed.
Old Aug 11, 2014 | 01:33 AM
El original's Avatar
El original
Common problem!? Never heard of an issue with glove door release on the forum ever.
Old Aug 11, 2014 | 01:57 AM
HOLLIDAYSC5's Avatar
HOLLIDAYSC5
You can find new and used latches on e-bay. And you can transfer your lock assembly to the new one.
Old Aug 11, 2014 | 08:54 AM
Stealth02's Avatar
Stealth02
I've got one. 15.00 shipped.
Old Aug 11, 2014 | 10:55 AM
Frankie 69's Avatar
Frankie 69
8th Gear
Removing the old lock from the latch is easy; there are youtube videos posted for it.
Old Aug 11, 2014 | 11:12 AM
Frankie 69's Avatar
Frankie 69
8th Gear
There is another long thread posted on the same issue from July 2010.
Old Aug 11, 2014 | 11:13 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
I'm assuming you bought a used latch. If it comes with a lock you will need to pick the lock to remove it. I ended up finding a cheap file cabinet key that went in the lock. The glove box lock only uses a few pins so it's easy to pick. You may get lucky and your key will be close enough to unlock it. Also try the small nail file found on some nail clippers. Just about anything you can slide into the lock and can wiggle while you do it may work.
Old Aug 18, 2014 | 03:50 PM
Frankie 69's Avatar
Frankie 69
8th Gear
Default Latch Received
Thanks stealth02 (Rob). I received the glove box latch today in good condition. I was quickly able to remove the lock from it with an old key and a small screwdriver (I will replace the lock with my old one). The deal saved me some $$$$.
Old Aug 18, 2014 | 05:06 PM
Stealth02's Avatar
Stealth02
No problem. Glad it helped you out.
Old Oct 15, 2018 | 07:03 PM
Jessica Torres's Avatar
Jessica Torres
1st Gear
Default Do you still have a glove box available?
Hi Stealth02,
Do you still have a glove box compartment? I need it for 2001 C5 Corvette.
Old Oct 24, 2018 | 06:38 PM
Crosis's Avatar
Crosis
is there an issue with the latches I haven't heard about? I went on vacation for a month this summer, leaving my vette locked in the garage. When I returned the glove box was open and the fuel door was open but the car was still locked.
Old Oct 25, 2018 | 02:37 PM
The Rabbi's Avatar
The Rabbi
2018 C5 of Year Finalist
St. Jude Donor '14,'18
Gremlins
To Glove Box Latch Broken
