C5 Body Panel Fitment
Old Aug 11, 2014 | 02:07 PM
Redandcurvy's Avatar
Redandcurvy
4th Gear
Default C5 Body Panel Fitment
Hello,
I am looking to purchase a 2001 C5 Coupe. The drivers side seems to fit well, but the passenger side seems a little funky in regards to the door, fender and hood fitment. You can see the odd gaps in the picture. Is this normal for a C5 or is it likely this car saw a ditch or 2 in it's lifetime. Car history report comes up clean.
C5 Panel Gap Issues
Old Aug 11, 2014 | 02:25 PM
3boystoys's Avatar
3boystoys
Look like the front fender could use a little adjustment on the top by the door.
Old Aug 11, 2014 | 02:47 PM
SG Lou's Avatar
SG Lou
That's exactly what I was thinking
Old Aug 11, 2014 | 03:26 PM
The_Gray_Ghost's Avatar
The_Gray_Ghost
My passenger side door to fender gap is atrocious. The driver's side is almost perfect.
I'm with others....with some adjustment you could probably get it where you want it.
Old Aug 11, 2014 | 09:19 PM
Before you would make the purchase, take the car to a trusted body shop and get their opinion on whether a simple adjustment would solve the gap problem or if it will require a more extensive procedure to make it look right.
Old Aug 12, 2014 | 06:18 AM
Redandcurvy
4th Gear
So I took the car to a shop and had it on a hoist so I could check it out. There is some metal guard thing on the bottom of the front bumper that was torn on the passenger side. It was actually torn out of the frame next to the radiator. The vehicle history report listed no accidents.
So the car hit something hard and low. Enough for me to walk away from that deal. Looking at the car a second time I noticed the headlight on the pass side wasn't even flush with the hood. You can see a little gap issue in the picture.
Thanks for all of your help.
Old Aug 12, 2014 | 08:02 AM
Shirl's Avatar
Shirl
2025 C8 of the Year Finalist - Modified
2021 C7 of the Year Finalist - Unmodified
$14,100 for that C5? I would have been all over it.. gap or no gap.. as long as the miles weren't sky high! That's an easy fix.
Old Aug 12, 2014 | 09:40 AM
MAC5's Avatar
MAC5
Shirl
With no detail about how many miles, interior condition, accessory functionality and how it rides, the OP might be walking away from a decent car. Most of what he describes in body panel misalignment seem to be easy adjustment fixes. That right front fender/door issue is the same as my 98 had. A simple adjustment fix, as are headlight cover lids.
The broken metal frame component is most likely the front end rail guard that did its job, another routine fix. Might have been worth a more thorough look, but if the buyer has mixed feelings, best he walks.
Old Aug 15, 2014 | 04:49 PM
Redandcurvy
4th Gear
114,000 miles. Car history shows over 12 owners in 6 states.
I've bought and sold a lot of cars. Body damage of any kind that the seller fails to inform me of is suspect in my eyes. When the car was on the hoist and I saw the lower front bumper by the radiator shroud on the drivers side looking ok and the passenger side having about a 3 inch gap, the owner said, "Plastic warps."
Then I saw metal that was torn. Not bent, torn. I walked away.
He also was kind enough to only raise the car 5 feet off the ground at his shop. Using a normal shop hoist. The man was hiding stuff and I found it. Or at least some of it.
The car may look great to 99% of the people. But 99% of the people are not lining up to pay for my next car.
Old Aug 15, 2014 | 05:20 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
Mine are about the same way. It's a build quality issue.
Old Aug 15, 2014 | 05:48 PM
The_Gray_Ghost
Alright...then why ask for our opinion then?
99% of the people responding to your thread were trying to help you out, and you dismissed 99% of the responses because you had already made up your mind.
Old Aug 15, 2014 | 06:26 PM
MAC5's Avatar
MAC5
First off welcome to the forum, and good luck on your continued search for a C5.
If you hang around here long enough you quickly realize that the quality of the responses is only going to be as good as the quality of the questions you ask. In your initial posting, your only concerns centered on body panel alignment and your suspicion of possible accident damage. Most of the replies were by owners with knowledge and experience fixing the usual misaligned body panels on the C5's.
Both of those problems you specifically mentioned are common to the model and relatively easy to fix.
Now on the other hand, if you had raised these two concerns along with the 114k miles, 12 owners, and registered in 6 states, I would have commented that the two misaligned body panels are the least of what you should be concerned with and would have recommended keep searching for a better car.
Good luck with your search.
Old Aug 17, 2014 | 10:01 AM
Redandcurvy
4th Gear
To be fair, I didn't mean to dismiss the responses. I didn't get the car history and see the car on the hoist until after the initial question. If I was looking at an Escort, I would have thought nothing of the panel fitment issues.
I've wanted a C5 since they came out. They are a beautiful and fun car.
I just feel a little disappointed that I'm finding out their build quality is just as poor as any other car. So no disrespect, I just feel like I found out unicorns are really just plain old horses with well placed tumors.
Old Aug 17, 2014 | 09:17 PM
jmccrary's Avatar
jmccrary
Lol...welcome to the Vette...it's not a quality thing...it's a character thing
To C5 Body Panel Fitment
