Dual climate control issues
Old Aug 12, 2014 | 08:16 PM
illselek's Avatar
illselek
5th Gear
Default Dual climate control issues
when i turn on either the heat or the air i get the opposite out of the driver side. when a/c is on cold air comes from the passenger side vents while warm air comes from the driver side vents. during the winter same thing happens with the heat. PLEASE HELP
Old Aug 13, 2014 | 11:41 AM
JeffDurbin's Avatar
JeffDurbin
Sounds like the air door actuator is bad. What codes are you getting?
Amazon Amazon
I was going to buy for $55 apiece (one for each side) but wasn't sure I would have by this weekend so I paid $70 apiece for Prime 2-day shipping.
If you get cold air on one side then you only need one of them.
There are threads on the forum that explain how to do the job. They predict a 3 - 4 project. I will try to take photos of mine this weekend.
Old Sep 12, 2014 | 09:59 PM
illselek's Avatar
illselek
5th Gear
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
How did your project go?
Old Sep 12, 2014 | 10:03 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I had that issue and replaced the left blend door actuator, When ac was on hot on the left cold on the right, Works like a champ now.
Old Sep 12, 2014 | 10:55 PM
dmarkshark's Avatar
dmarkshark
Ok, once again, as mentioned, check for any codes? Sounds like a bad actuator.
To Dual climate control issues
