Leaving the headlights up
Old Aug 17, 2014 | 06:47 AM
Sonny71's Avatar
Sonny71
Oldtimer
Default Leaving the headlights up
I know that if you turn the headlights on and then turn the switch to parking lights the headlights remain open. Is there a way to keep them open with the engine off---mine are filthy and need a good cleaning.
Thanks and Remember to WAVE Name:  vertwave.gif
Old Aug 17, 2014 | 08:03 AM
65GGvert's Avatar
65GGvert
Thanks and Remember to WAVE Attachment 47820198
They operate the same with the engine off (and key off). Turn on headlights and back to park and they'll stay up. The park lights will stay on.
If you want them up with park lights off, roll them up manually with the little wheel.
Third choice, turn them on, back to park, and disconnect battery.
Old Aug 17, 2014 | 08:04 AM
vpshockwave's Avatar
vpshockwave
There is a manual **** on the back of each headlight that lets you manually raise and lower it. It's covered by a round rubber boot. Pretty easy, but it takes quite a few turns to do it manually. It will do the trick however
Old Aug 17, 2014 | 09:04 AM
This will do it. That's the procedure I use when I am detailing my car.
Old Aug 17, 2014 | 09:28 AM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
If you manually raise them with the car off, will that mess up the alignment of the lid covers when you turn the car on? If you manually open them, do you need to manually close them as well?
Old Aug 17, 2014 | 09:36 AM
Mickeyrx70's Avatar
Mickeyrx70
No. You can close them with the switch without any issues. I did it plenty of times when I installed the Bi-xenon lights.
Old Aug 17, 2014 | 09:56 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
When I clean my car all I do is turn on the headlights and then back to parking lights, It doesn't take that long to clean them, It seems to me that opening them and then disconnect the battery is a lot of un needed work, Same for manually opening them up, Am I missing something here?
Mr.Bill
Old Aug 17, 2014 | 10:12 AM
Sonny71's Avatar
Sonny71
Oldtimer
Mr.Bill
Thanks Bill, I'm with you
Old Aug 17, 2014 | 10:37 AM
MSG C5's Avatar
MSG C5
Mr.Bill
That's pretty much what I do, however I was thinking about the best way to leave them up during shows as many guys ask me about my ACA HID lights. I just want to make sure if I use the ***** to manually turn them up/open, that I don't misalign them in any way and wear down the gears, etc. Plus, I wanted to know if once I manually raise them, whether I need to manually lower them or can I simply turn the car back on and lower them with the lights switch.
Old Aug 17, 2014 | 11:30 AM
mtndv8's Avatar
mtndv8
I don't recall exactly how long the delay is but there is a timer (within the module on the headlight system, I believe) that turns all the lights off and closes the buckets if left on without the engine running more than 10-15 minutes.
I believe Junkman documented it somewhere but this feature could be painful if you get distracted for a bit then get your finger(s), hand, other body parts in the way when it closes...
jrose7004's Avatar
jrose7004
With the key on but engine not running turn the lights on, clean them and turn them off.
Old Aug 17, 2014 | 11:10 PM
yanmar's Avatar
yanmar
Default headlight **** and rubber booth cover
I have raised my headlights manually in the past with the *****, but my 99 coupe does not have the rubber booth covers. What is the purpose of the booths and were they added later than 99 ? Where might i find the booths for sale ? Thanks......
Old Aug 17, 2014 | 11:27 PM
dbgoodwin's Avatar
dbgoodwin
I always leave my buckets up with the parking lights on anytime I'm running into a store or getting gas. For some reason it makes me feel better, like it's less wear on the motors/gears.
Old Aug 17, 2014 | 11:32 PM
65GGvert's Avatar
65GGvert
Not sure what a rubber booth cover is.
Old Aug 17, 2014 | 11:50 PM
scarecrowkc5's Avatar
scarecrowkc5
It covers the **** that you use to raise the lights with.
Old Aug 17, 2014 | 11:55 PM
Mr.Bill's Avatar
Mr.Bill
I thought that was a cover?
Old Aug 17, 2014 | 11:56 PM
65GGvert's Avatar
65GGvert
So a rubber boot?
To Leaving the headlights up
Old Aug 19, 2014 | 02:23 AM
DanSavage's Avatar
DanSavage
I don't know if these will fit your `99, but these are available on eBay.
http://www.ebay.com/itm/00-04-Corvette-C5-93-97-Firebird-Trans-Am-Headlight-Motor-Cap-Rubber-Boot-NICE-/151307980444?pt=Motors_Car_Truck_Parts_Accessories&hash=item233aa88e9c&vxp=mtr
Old Aug 19, 2014 | 08:04 AM
LoneStarFRC's Avatar
LoneStarFRC
You can do it either way. Just don't crank down hard when doing it manually. Just tighten snug when they reach the stops; no gorilla action.
Old Aug 19, 2014 | 08:06 AM
LoneStarFRC
Originally Posted by DanSavage
I don't know if these will fit your `99, but these are available on eBay........
They will not. The early headlight motors are constructed differently and all C5s from '97 to '99 came without them.
