Driver's Side Door Control Module
Old Aug 18, 2014 | 02:01 PM
kirtp's Avatar
kirtp
Navigator
Default Driver's Side Door Control Module
My driver's side door control module works properly but does not light up at night when the lights are on. Any suggestions on what the problem may be?
Old Aug 18, 2014 | 03:49 PM
rws.1's Avatar
rws.1
Not sure what part you are talking about... the Door control Module (DCM) is located behind the door panel, between the panel and the door skin.
It is not visible with the panel on and doesn't have any lights on or on it.
Old Aug 18, 2014 | 04:32 PM
jph1972's Avatar
jph1972
Neither did mine when I bought my Vette. I just ordered one online for $100 and replaced ...all is good now.
Old Aug 18, 2014 | 06:30 PM
kirtp's Avatar
kirtp
Navigator
I am apparently mistaken on the name of what my original question is about. Sorry about that.
This is the driver's side power window/lock switch assembly. All the switches work properly. It no longer lights up like the passengers door does.
Last edited by kirtp; Aug 18, 2014 at 07:31 PM. Reason: Needed more information added
Old Aug 19, 2014 | 09:39 AM
irljr's Avatar
irljr
4th Gear
Same problem here--switches work, but no lights on drivers side only. Would be interested in fix. Thanks in advance.
Old Aug 19, 2014 | 01:59 PM
dadaroo's Avatar
dadaroo
Could be several things including bad switch or no power inside the door for the switch light circuit or bad ground. Not as likely that all the bulbs are bad but could be. They can be replaced.
Can help you later with diagnostics but rather busy and not at home now.
To Driver's Side Door Control Module
