[Z06] Play in steering wheel
Old Aug 24, 2014 | 09:30 PM
C7LOU's Avatar
C7LOU
Default Play in steering wheel
My 03 Z's steering has free play on it. Turning the steering well left or right does not bring instant response from the tires. I notice it much more as my 2013 CTS is much more responsive and tight. What is the cause for this and how is it fixed?
Old Aug 25, 2014 | 01:29 AM
momo20's Avatar
momo20
are you leaking power steering fluid?
how many miles are on your Z?
Old Aug 25, 2014 | 06:10 PM
C7LOU's Avatar
C7LOU
No leaks and 29k miles
Old Aug 25, 2014 | 09:18 PM
bumble-z's Avatar
bumble-z
Has your Harmonic balancer ever been removed or pinned/keyed or the power steering rack removed?
Old Aug 25, 2014 | 09:52 PM
randyfl's Avatar
randyfl
check the connection at the rack. There is a bolt there that may have come loose. Mine had a little play after I pinned the crank. I had to remove the bolt and clean the threads. Re-tightened and solved the problem. It does not take much play to really feel it the wheel.
Old Aug 26, 2014 | 07:45 AM
C7LOU's Avatar
C7LOU
The car has never been touched in terms of these items. I did check that bolt and it's tight.
Old Aug 26, 2014 | 08:11 AM
1FUNC5's Avatar
1FUNC5
Have you had the car aligned recently?
Old Aug 26, 2014 | 07:42 PM
C7LOU's Avatar
C7LOU
About two years ago, but I just swapped out tires and the wear was perfectly even on all four.
Old Sep 8, 2014 | 07:33 PM
C7LOU's Avatar
C7LOU
Any other thoughts on this?
To Play in steering wheel
