Yet another simple TPS question
Old Aug 26, 2014 | 12:52 PM
olddude's Avatar
olddude
3rd Gear
Default Yet another simple TPS question
I have tried to read all of the related posts but confusion still racks my senior brain. Simply stated - if I replace my rt front TPS sensor on my 99 C5 coupe, do I need to do "anything" else other than the relearn procedure?
Old Aug 26, 2014 | 01:02 PM
65GGvert's Avatar
65GGvert
Go through the entire relearn procedure. Start with the LF, then RF, then RR, then LR in that order all in one session.
Old Aug 26, 2014 | 01:03 PM
MAC5's Avatar
MAC5
You pretty much have it, just have to make sure you do all four and the DIC confirms.
Old Aug 26, 2014 | 01:23 PM
C5Txfan's Avatar
C5Txfan
I fixin' to replace my sensors on my '04 and I have the reprogramming instructions .. but I have a question for those that reprogrammed their sensors - how big of a magnet do you need and where did you get it ?
Old Aug 26, 2014 | 01:27 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I bought mine from Tire Rack, I have read where some have used an old speaker magnet.
Old Aug 26, 2014 | 01:30 PM
Navybluevette's Avatar
Navybluevette
St. Jude Donor '12-'13-'14-'15-'16-'17
I got mine on Ebay...... If you live close to Plano you can borrow mine.
Old Aug 26, 2014 | 01:37 PM
C5Txfan's Avatar
C5Txfan
I appreciate the offer .. but I'm in Arlington. I'll probably check out a hardware store or HD / Lowe's for one.
Old Aug 26, 2014 | 02:15 PM
Bill Vett's Avatar
Bill Vett
I have a friend who said to put the magnet in a sock. When you place it on the wheel it will not scratch the clear coat or chrome. Also makes it easy to remove.
Old Aug 26, 2014 | 02:58 PM
Fcar 98's Avatar
Fcar 98
When i reprogram my sensors i don't but the magnet on the wheel i put it on the tire right on the sensor. I use the gm tool I bought because we have 5 cars that have the sensors
Old Aug 26, 2014 | 08:40 PM
Catman58's Avatar
Catman58
Awhile back I bought a dial indicator magnetic base at Home Depot. This magnet works great on mine. It was pretty cheap to under $10.00 as I remember.
Old Aug 26, 2014 | 09:51 PM
Boss75's Avatar
Boss75
I just did this today and replaced the two in the rear with the Dorman sensors. I did the relearn with a magnet and everything went fine. They register the pressure like they should.
Old Aug 27, 2014 | 01:06 AM
wamara's Avatar
wamara
Cruise-In II Veteran
Hi C5T,
It's been said before here, but I guess it's worth repeating - train your new sensors BEFORE you install them in your wheels. This ensures none are defective, and it's a lot easier too. Just climb inside the driver's seat with your sensors, a magnet, and some post-it notes or baggies labeled with your respective tire positions (i.e., LF, LR, RF, RR). As you go through the training sequence on your DIC, just put the magnet to a sensor, and when it beeps, label which wheel it goes to, set it aside, and go on to the next one. No worrying about having a powerful enough magnet (within reason of course), scratching your wheels, etc. I've done this multiple times and it has always worked like a charm. Good luck.
Old Aug 27, 2014 | 01:33 AM
El original's Avatar
El original
Originally Posted by wamara
Hi C5T,
Great idea, something that I will remember. Thanks for repeating yourself, lol.
Old Aug 27, 2014 | 04:27 AM
thisMSGgood4me's Avatar
thisMSGgood4me
Hi C5T,
Forget the post-it notes and baggies. Just use a Sharpie permanent marker and write the respective tire positions right on the sensors.
Old Aug 27, 2014 | 07:23 AM
olddude's Avatar
olddude
3rd Gear
Thanks to all; I think I can move forward with it now.
To Yet another simple TPS question
