C5 Electrical Problem
Old Aug 26, 2014 | 07:38 PM
pats67copo's Avatar
pats67copo
Default C5 Electrical Problem
Hi,
Can anyone help? I'm having problems with my drivers door power control (windows ,locks, mirrors and memory) I thought it was the controller going bad so I replaced it and am still having the same problems. Sometimes they work fine other times the windows won't work, the door lock only controls the drivers door, the memory button only changes the mirrors and the control itself doesn't light up. I have no idea what to look for so if anyone has any thoughts would love to hear from you.
Old Aug 27, 2014 | 01:19 PM
cor28vettes's Avatar
cor28vettes
Originally Posted by 8VETTE7
Look at the following thread and part that talks about the connectors that are inside the A-Pillar. Likely the pins in the connectors are NOT making good contact. Need to pull back the accordion tube , fish out the connectors and pull them apart and inspect and correct the pins that are bent:
http://forums.corvetteforum.com/c5-t...-there-is.html
