2000 driver door won't lock
Old Aug 31, 2014 | 03:52 PM
jpink1's Avatar
jpink1
2nd Gear
Default 2000 driver door won't lock
my 2000 vet. drivers door will not lock with door button or key fob, but will unlock with both when manually locked. all functions work except power locking mode. what should I check first?
Old Aug 31, 2014 | 05:17 PM
stu12dozen's Avatar
stu12dozen
Most likely it is the door lock, mirror and window module. You can get a new one from one of the forum vendors or a used one from a wrecking yard.
If you're not mechanically challenged and handy with a soldering iron then you can replace the relay in the module: https://www.corvetteforum.com/forums...le-repair.html
Old Aug 31, 2014 | 08:11 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Old Aug 31, 2014 | 08:34 PM
65GGvert's Avatar
65GGvert
I'd try changing the locking relay in the door control module before I bought a new or used module. You don't have much to lose but a little time.
Old Jul 18, 2016 | 09:23 PM
Georgies's Avatar
Georgies
None of the pictures work... like soooo many usefull threads on this forum. Any reason why? Is thr server have too small capacity?
Its honestly annoying...soo many cool threads and pics dont load...what gives?
Old Jul 19, 2016 | 02:56 PM
mike48750's Avatar
mike48750
Picture worked for me. Keep in mind this thread is 3 years old, some pics get lost in the shuffle. Good luck. Mike
To 2000 driver door won't lock
