DIY cam install?
pin the crank while you are down there..
old sprocket coming out..
Hello stock cam!!
Almost forgot the dowels was so excited to get the damn thing out!!
New "Jam Cam"
Out with the old in with the new..
Putting it back together..
Now they say the pullers from autozone don't work I say they do and like a champ..
All out..Now before I put the new crank sprocket on I put it in the oven so it would slide on easier which it did after it was done BUT don't be a dumbass like me and put grease on it before it goes in the oven..Yeah it got smoky in the kitchen...oooops.....
Looks timed to me..
I had it in when I did the whole thing..
here is the springs coming out..
Take off the coilpacks and remove the 4 8mm bolts and you should see this. Don't mind the crooked looking one I had loosened it before I took the pic
Take out this 8mm on the rocker.
Take the pushrod out..
This is what you should have..
Then take the rocker arm pedestal out and for some reason mine was on upside down...wonder why?
all out
and in order
Here is the tool..besides the guy using it..
I just used fitting you find in a compression tester..Figured I better not drink during this process..
Take out the shrader valve and screw it into the cylinder you are working on. I also used the TDC method because I didn't wanna end up what I did on the first one almost dropping the damn thing..
Tighten everything up and then start cranking down..SOme of the locks needed a tap on them to come loose..
Once you take those locks off you just pull the spring/retainer out and your left with the seal and seat.
old stuff.
I used a pair of plies and a little twist and turn and they come right out and used a magnetic tool for the seats to come out.
The install is the opposite oil everything up drop the seat in. Put the new seals in and I used the tool that your supposed to use I didn't like the socket and hammer idea. It was 7 bucks off ebay..J-42078 Valve Stem Oil Seal Installer
I read somewhere that the locks are a pain to install and use some lube to keep them on the top of the valve. It worked like a champ..
one is done..
15 more to go..It goes quick after the first one..all done!!!
after reading your response i think i may go this route. You can loose money but you can loose the experience you've gain by doing it your self. also i think it would be fun. but on the other hand i could pay him that way its tuned right away and nothing would get hurt getting to his house a hour away. I'm like 70>30 with it.
bottom line $850 is a rock'n deal cam and parts are over $400 tunes average $500 but if you have the tools being able to say you installed it .......PRICELESS!
If you let a mechanic do it, and something happens, it's on him. This would be the option I would go with. His price is amazingly low as he's essentially charging you about $300 to install the cam, which is unheard of.
If he really will do the work for $850, that's one heck of a deal.
