z06 stubby conversion help
Old Sep 5, 2014 | 09:26 PM
porterhouse's Avatar
porterhouse
Cruising
Default z06 stubby conversion help
So guys I bought the stubby metal antenna and when I go to remove the tall factory power antenna I don't know what to do about the plastic cable that runs to the antenna. Can I get some help here? 02 z06 and I just applied my rear blackout kit so I don't wanna take out tailight if possible. Thx guys
Old Sep 5, 2014 | 09:37 PM
brplatz's Avatar
brplatz
If you have to, isn't the taillight 2 screws and about 20 seconds?
Old Sep 5, 2014 | 10:14 PM
Ron C!'s Avatar
Ron C!
You don't take off the entire assembly, just unscrew the mast and replace with the stubby. Should take no more than 10 seconds.
Old Sep 5, 2014 | 11:22 PM
OKZ06's Avatar
OKZ06
St. Jude Donor '13-'14
Unless his was like mine where it was completely seized to the base actually had to cut and chip the old one away
Old Sep 6, 2014 | 11:42 AM
porterhouse
Cruising
I just removed the entire antenna assemble and plastic cable from the outside of the car. Now I have no thread to adapt the antenna to? Anyone have this problem
Old Sep 6, 2014 | 12:30 PM
Stroker87's Avatar
Stroker87
I be leave the stubby's are for NON power antenna's
so unless your kit came with a base your out of luck..........
To z06 stubby conversion help
