Spring Noise?
Old Sep 6, 2014 | 11:27 PM
coh2000's Avatar
coh2000
Default Spring Noise?
Your comments please on a noise issue I have:
There are 2 springs (approximately 6” in length) that are located midway front to back and side to side clearly visible on the underside of my 2003 C5 coupe(They are not covered by a panel) .
These may be a spring within a spring? They are about an 1” in diameter.
They appear to be suspending an exhaust pipe on my 2003 coupe.
The dealer says that’s what making the ‘clunking noise’ I hear.
Has anyone experienced this noise with these springs?
Old Sep 7, 2014 | 07:25 AM
7LitreC5's Avatar
7LitreC5
Those springs are part of the exhaust hanger. I have had mine rattle a little bit but not clunk.
Old Sep 7, 2014 | 12:41 PM
coh2000's Avatar
coh2000
Default Exhaust Springs
Do you know if these springs have any sort of 'coating' on them when they are new?
Old Sep 7, 2014 | 12:48 PM
7LitreC5's Avatar
7LitreC5
Mine didn't. I slightly bent the bracket to put some tension on the spring (only 1 of mine was loose) and that took care of it.
Old Sep 7, 2014 | 12:52 PM
coh2000's Avatar
coh2000
i loosen both of mine and slightly turned them before tightening them back up.
I think it made the noise worse. Maybe they loose there 'tension' (not as stiff), and then they make noise.
To Spring Noise?
