Window valet not working
Old Sep 10, 2014 | 11:56 AM
tomikem's Avatar
tomikem
Default Window valet not working
When I use my window valet, the windows on my 99 'vert only close half way then the horn sounds and they go back down. I have tried the valet with both doors open and no obstructions.... same thing. I have paired my fob pressing both "lock" and "unlock" for several seconds. Help!!!
Old Sep 10, 2014 | 02:03 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Remove it and reinstall it and try that.
Old Sep 10, 2014 | 05:00 PM
tomikem's Avatar
tomikem
Thanks for the info Bill... problem still persists
https://www.corvetteforum.com/forums.../Cdnsmilie.gif
Old Sep 10, 2014 | 05:17 PM
Mr.Bill's Avatar
Mr.Bill
Have you tried to recalibrate the windows? Also I believe there is a setting for strength.
File Type: pdf
Old Sep 10, 2014 | 05:50 PM
allred's Avatar
allred
tomikem, did you simply remove & re-install the physical device, or did you go through the complete programming procedure?
I had the exact same problem you are speaking of and cured it by simply re-programing the window valet......and it has been fine ever since.
Old Sep 11, 2014 | 07:40 PM
dankhts's Avatar
dankhts
Ok so while I'm having a brain fart while installing and programming my WV, how do I enter 0's 9's and 7's on the DIC for my PIN? The buttons are only numbered 1 to 5.....
Old Sep 11, 2014 | 08:08 PM
Mr.Bill's Avatar
Mr.Bill
I believe you only enter the last 4 numbers and they should be in a 1-4 format.
I posted the booklet for you a few days ago, It is in there.
Old Sep 11, 2014 | 08:14 PM
Mr.Bill's Avatar
Mr.Bill
Additional Power Window Disclaimer.
By entering a portion of the following code to enable the remote
control of power windows, you indicate that you have read,
understand, and fully agree to all the TERMS OF USE and that you
accept all the risks of bodily harm and property damage and will hold
Top Down Tech harmless of any future consequence. If you do not
agree to this, do not enter the code and do not use the product, instead
see paragraph 1 to return the Product. The PIN code used for window
4
access is the last four digits of the serial number shown below and on
the product. Entering the PIN code will be considered equivalent to
signing this liability waiver.
Old Sep 11, 2014 | 09:07 PM
dankhts's Avatar
dankhts
I get it now .....guy who sold it to me said the PIN was the last 4 digits of the car's vin.....mine's 7's 9's and 0's.....
To Window valet not working
