Brake Caliper/Bracket Paint
Old Sep 11, 2014 | 10:57 AM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Default Brake Caliper/Bracket Paint
What is the best brand, color code, to duplicate the GM red brake caliper paint?
I am upgrading my brake kit to the Baer Eradispeed +2 rotors (front and back) and the front brake kit has new caliper brackets, however they are silver (not black as other online pictures show) and I want to paint the brackets similar to my current set up. The challenge is that my original brackets were painted by a shop that is no longer in business and I'm trying to match up as closely as possible.
I knew the +2 kit had extensions for the rear calipers but I wasn't expecting to have to install new caliper brackets in front. I guess I didn't read the product description closely enough. No biggie, I just need to paint them first.
Thanks!
Old Sep 11, 2014 | 12:11 PM
66dts-v's Avatar
66dts-v
No idea what color they used, but I would think reds would be close on any straight red you choose. POR-15 red should work well and last.
Old Sep 11, 2014 | 12:42 PM
MSG C5's Avatar
MSG C5
Thanks. Since I'm only painting the front caliper brackets, I want to match them up to the OEM GM Red caliper paint as closely as possible. I'm colorblind at times (ask my wife), and there are so many reds available, I just want to find out if there is an "official" GM red caliper color code. I know this may be OCD, however it is Corvette-related.
Old Sep 11, 2014 | 01:22 PM
66dts-v's Avatar
66dts-v
Well, I'd be surprised if the POR-15 red was different enough to notice from the bracket to caliper, but I've never put them next to each other. I know the Chevy Orange engine enamel was spot on to existing orange on my truck motor and my calipers are silver, not red.
Old Sep 11, 2014 | 01:36 PM
MSG C5's Avatar
MSG C5
Thanks. Is "POR-15" the color code or is that specific to a brand? I know that Autozone, etc. has paint specific to brake calipers/hardware so do I cross-reference that paint code?
Old Sep 11, 2014 | 01:47 PM
Maxx_Z06's Avatar
Maxx_Z06
C5 COTM Coordinator
I used Rust-Oleum "Safety Red" paint on my calipers after grinding them down for my Baer Eradispeed +2 rotors. The rears matched up the front so well i even touched up the fronts afterwards with it.
Old Sep 11, 2014 | 01:50 PM
66dts-v's Avatar
66dts-v
POR-15 is damn near bomb proof, seriously best thing next to powdercoating (I usually powdercoat because I have a setup).
http://www.por15.com/CALIPER-PAINTING-KIT_p_58.html
Old Sep 11, 2014 | 02:07 PM
brucemac64's Avatar
brucemac64
paint the bracket black!!!!!
Old Sep 11, 2014 | 02:47 PM
On my last two C5s I have used Folia Tec caliper paint in bright red. Can't say for sure if it matches what you have on your calipers, but it is a close match to torch red.
Old Sep 11, 2014 | 04:08 PM
MSG C5's Avatar
MSG C5
I thought about that, however since the rear brackets are also painted red, I would have to paint those also. Plus, I personally like the brackets and calipers both being read as it fills in the wheel.
Old Sep 11, 2014 | 07:02 PM
MSG C5's Avatar
MSG C5
Is the full kit required or just the paint? They brackets don't need to be cleaned or de-greased and the brackets and other components are zinc-coated.
Old Sep 13, 2014 | 10:56 AM
MSG C5's Avatar
MSG C5
Per my exchange with Toque, he did the same thing. Did you apply a clear afterwards or did the gloss finish of the Rustoleum Safety Red match up to the finish of the OEM calipers?
Old Sep 13, 2014 | 11:22 AM
momo20's Avatar
momo20
MSG I used the red engine enamel on my hat's or brackets , I went with a white primer 3 coats..then the actual red paint then with 4 coats of clear coat with a light sanding between each coat, it match's almost perfectly
To Brake Caliper/Bracket Paint
