Using an accurate fluke meter I get 0.28 volts with neg. wire to battery-and red wire in antifreeze-when putting pos. red lead to neg battery-and black neg lead into antifreeze- I get a reading of 0.05--what gives and whats accurate?
I learn something every day! I did some internet research on this and it seems reasonable. (EVERYTHING YOU READ ON THE INTERNET IS TRUE, RIGHT?) Essentially the voltmeter test checks for electrolysis that eats the radiator aluminum, it does not tell you the freezing point like a hydrometer. Apparently after some time the dex gets acidic and electrolysis starts. OR - there is a bad ground from an electrical component and the circuit completes itself through the rad creating a different type of electrolysis. Both with the same result, eating away the rad. So there are two fixes for the problem, one to flush the rad and the other to fix the ground connections. If you unhook the battery and the voltage drops it is the bad ground connection type, if it stays the same it is acidic dex. A reading over 100 mV (0.1 DC) is not good. Mine reads 130mV so it looks like i am going to get to work on my car again.. yay!
BTW I read that the + or red lead goes in the dex, the other to the battery ground - that makes sense electrically.
But first I am going to see if there are any other points of view.
I worked in a heavy truck fleet with a bunch of 6v92 Detroit's, the electrolysis from bad grounds would eat the cylinder liners on the Detroit's for lunch, radiators are not the only casualty, if I recall, more than 4 tenths of a volt was a problem.
I also have read that anything below .5=5/10 of a volt is ok
