Need help with bad head liner
Old Sep 22, 2014 | 08:15 AM
Ghost Vette's Avatar
Ghost Vette
Default Need help with bad head liner
I have a sagging head liner in a spot about the size of a dollar bill and think it time to get it replaced. I thought I would try a little DIY but wanted to know if anyone has attempted this and what are the steps to fix it. This is on a coupe targa top.
Old Sep 22, 2014 | 08:23 AM
bjones7131's Avatar
bjones7131
I saw a thread a while back on DYI. On this small of a top I wouldn't think it would cost very much at an uphostery shop to have it done. I have had a couple done over the yrs on other vehicles for around 100.00. Good luck, gooogle search may turn up something.
Old Sep 22, 2014 | 09:48 AM
Ghost Vette
Thanks bjones for reply.
Old Sep 22, 2014 | 10:31 AM
Blue Thunder's Avatar
Blue Thunder
Cruise-In I Veteran
National Champs Gators 4 St. Jude '09
Just had mine redone in the 2004.
BK&D Auto Upholstery, Smyrna - $150.
Done.
Old Sep 22, 2014 | 03:19 PM
Ghost Vette
Done.
You know that seems the way to go. Leave it up to someone who knows what they are doing I guess.
Old Sep 22, 2014 | 03:43 PM
innerconx's Avatar
innerconx
St. Jude Donor '15
Just an FYI - I have a similar issue - the headliner on the targa top is just starting to sag a little bit.
Recommended Forum Shop down here has quoted me 150 to repair same day.
Old Sep 22, 2014 | 08:55 PM
sfc rick's Avatar
sfc rick
If your not Goober, you can fix it for $10.00 It's not rocket science. Just go to Walmart and get the 3M spray adhesion and fix it yourself.
Old Sep 22, 2014 | 08:58 PM
bjones7131's Avatar
bjones7131
Tell us how gomer, details and materials
Old Sep 22, 2014 | 09:05 PM
sfc rick's Avatar
sfc rick
See post #7
Old Aug 22, 2015 | 10:38 AM
jdbuddy's Avatar
jdbuddy
Originally Posted by sfc rick
See post #7
How do you remove the headliner? It seems to be attached to matting material/board and the board is attached/glued to targa top. Looks like pulling it off could damage the board.
Old Aug 22, 2015 | 03:30 PM
bjones7131's Avatar
bjones7131
That is what i found as well. I pulled it loose enough to reglue but it didn't stay so i took mine to an upholstery shop and had it done for 85 bucks.
Old Aug 22, 2015 | 07:40 PM
Maybe this will give you some ideas:
Old Aug 23, 2015 | 01:51 AM
1Willy1's Avatar
1Willy1
good excuse to have it redone properly in a better material, a vinyl or suede would be really nice.
Old Aug 23, 2015 | 09:05 AM
DRAFT1's Avatar
DRAFT1
I bought new 1/2 foam padding and a faux leather material at a fabric store for $18. A can of 3m super adhesive was about $25. Pulled out the entire pad and liner and made a template for the new pad. Cut the liner about 1 1/2" oversize and trim as needed. One thing I discovered is that you can tuck the edges along the sides and front but not the back of the lid. For the cost, I am very happy with the results. I should add that I used the .doc in Vetteman Jack's above thread.
Old Aug 23, 2015 | 09:45 AM
m6 c5's Avatar
m6 c5
I did it in my el camino, went to the store and bought some new headliner and got some loctite spray glue, then trimmed to fit. I originally used medium hold but that didnt last very long so I went back with the permanent spray glue and its held up for several years now.
Old Aug 23, 2015 | 12:17 PM
S.C. vette's Avatar
S.C. vette
Veteran: Marine Corps
Here are the steps I took, got a nice satin black fab, very tight weave, from Walmart. Cut an oversized pattern using the shape of the opening. Used a plastic 6" mud knife to break loose the old headliner. Take your time, you can preserve the foam headliner backing and expense. While doing the headliner, started to remove the cheap, crappy, falling apart fabric from the molded foam. Take your time! Next steps to follow...
Old Aug 23, 2015 | 12:20 PM
S.C. vette's Avatar
S.C. vette
Slowly work the puddly knife around the edge, esp the corners. Removing a fabric a bit at a time.
To Need help with bad head liner
Old Aug 23, 2015 | 12:23 PM
S.C. vette's Avatar
S.C. vette
Finish removing the old fabric... Slowly, not so as to damage the foam.
Old Aug 23, 2015 | 12:26 PM
S.C. vette's Avatar
S.C. vette
Now you can begin to work the foam from the top, slowly so as to not damage or crack it. The spray foam used it delicate.
Old Aug 23, 2015 | 12:33 PM
S.C. vette's Avatar
S.C. vette
Don't bother with the old 3m spray, it won't budge.
