Led lights
Old Sep 22, 2014 | 03:48 PM
Bomber39's Avatar
Bomber39
3rd Gear
Default Led lights
Purchased some led lights and now the system shows there is a bulb out . Blinks fast. Then put in the adaptor that should fool the system but it doesn't . When you turn the blinkers on the MPH light blinks too . Any ideas that I can do to fix this problem . Tyler
Old Sep 22, 2014 | 11:59 PM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
Your problem is caused by the reduced current of the LED bulbs which triggers the bulb-out indicator.
Our plug-and-play hyperflash harness will fix the problem in 5 minutes and you won't need to splice in any resistors to the factory wiring. In addition, if you switch to LED tail lights, our harness will prevent hyperflash with those as well.
Order here:
http://shop.radioflyerinnovations.co...arness-027.htm
