RH Outside Mirror Motor
Hello, does anyone know if I can replace my Motor w/memory with another Motor without memory. Since no one else drives the car but me, I could care less that the memory feature of that mirror is used and I could save myself a hundred bucks. Thanks.
Here is a good door panel removal link in case you need it.
http://www.vetteessentials.com/instr...or_handle.html
If you want to just replace the motor into your existing painted housing I have a guidance document I made. Not at home now but I can post. Not hard to do, just have to pull off the actual mirror and remove the door panel but my guidance is very detailed at 2 pages long on how to remove and replace the mirror. Let me know.
