Need some help
Old Sep 27, 2014 | 09:51 AM
bjv58's Avatar
bjv58
Default Need some help
Hello, went to turn on headlights and they did not come on.
Opened the doors by hand still no lights. Any help. Thanks
Old Sep 27, 2014 | 09:57 AM
jakecol's Avatar
jakecol
Maybe better info. on the "Tech & Perf" Community. Good Luck
Old Sep 27, 2014 | 09:58 AM
jakecol's Avatar
jakecol
P.S. Bill Curlee is a wealth of knowledge.
Old Sep 27, 2014 | 10:04 AM
Sonny71's Avatar
Sonny71
Oldtimer
Battery check
Old Sep 27, 2014 | 10:43 AM
dadaroo's Avatar
dadaroo
Need to know if you have original/OEM headlights or if you have some kind of HID or similar upgrade. From your description the lights do not come on and the doors so not open, correct?
Also, can you get the running and park lights to come on by rotating the MF switch?
Once we have that info we can better start diagnostics.
One more thing, if you have Twilight Sentinel, can you turn it on and darken the sensor and see if they come on and the doors open? Sensor is on the left side of the driver defrost vent if I recall correctly.
Old Sep 29, 2014 | 05:07 PM
bjv58's Avatar
bjv58
Hello, I have o.e.m. headlights, running lights & parking lights work.
NOTWILIGHT SENTINEL tHANKS
Old Sep 30, 2014 | 08:42 AM
dadaroo's Avatar
dadaroo
Since you created another identical Thread in the Tech section, let's do all the diagnostics and updates there. Respond to what Bill asked for and then we can go from there.
Old Sep 30, 2014 | 09:01 AM
Nate@VanBortelChevy's Avatar
Nate@VanBortelChevy
Platinum Supporting Dealership
Check the fuses. If they both aren't working it might be an issue with the headlamp control module. But check the basics first.
To Need some help
