New Battery Recommendation
Old Sep 27, 2014 | 08:27 PM
frsr06's Avatar
frsr06
Default New Battery Recommendation
Looking for an update a on recommendation for a new battery. Went to Autozone today and they said that the Optima red top was not available - and did not know when it would be available again. Any other recommendations?
Old Sep 27, 2014 | 08:36 PM
tcrote5516's Avatar
tcrote5516
Yea, go somewhere else and find a Redtop You already found the best battery IMO.
Any other auto parts store should have it in stock.
Old Sep 27, 2014 | 08:40 PM
65GGvert's Avatar
65GGvert
Since you're asking for opinions, forget the red top and get a reliable battery. I just bought one from Autozone and googled for a discount coupon, saved 25% and got a 7 year Duralast Gold battery.
Old Sep 27, 2014 | 08:52 PM
tcrote5516's Avatar
tcrote5516
Too funny. If your going to cheap out and buy a Duraleak battery at least get the Duraleak Platinum. The Platinum is AGM which is better (but still not as reliable or light as a spiral AGM gel cell), the gold is just your run of the mill acid/grid style prone to leaking and a HORRIBLE choice for a Corvette given the ECM and frame layout.
Red top is the right choice when you concider what's sitting under that battery tray but if you want to roll the dice with a Duraleak be my guest.
Old Sep 27, 2014 | 09:36 PM
Unless the quality of the Red Top has improved in recent years, stay away from it. There for a while there were a number of reports of the battery dying when it was not very old. But perhaps things have changed.
I had a Red Top in my car back in 2010 and right after the three year mark, it died. I replaced it with a Sears Diehard Platinum and it has not given me one problem in the four years I have had it in the car.
Old Sep 27, 2014 | 10:36 PM
65GGvert's Avatar
65GGvert
My car (04) uses the top posts and I've never had any leaking. I don't want AGM or I would have bought it. The last battery lasted 8 years and was still starting the car. You're living in the past with the leaking threats. I wouldn't put an Optima in my car if it was free. That's just me, a lot of guys on here love them. Maybe it's because they spent so much they feel like they have to defend them. Google the Optima complaints on the forum. I also had an 03 that had an AC Delco in it for over 7 years with absolutely no issues. I'd choose that over most other batteries if I were looking.
Old Sep 27, 2014 | 11:25 PM
El original's Avatar
El original
Got one from your friendly GM dealership...gorgeous battery at a very reasonable $94- and a four year warranty. Beat that. Made for my Corvette too!
Old Sep 27, 2014 | 11:34 PM
striper's Avatar
striper
Well to all of you who don't like Optimas, the red top I use I bought in 1999 to replace the crap AC Delco in my '98 C5 coupe. When I traded that car I took it out and put it in my new Z06 when I bought it in 2003. 15 years later it still works which is longer than any battery should last! Coincidentally, I think I'll be replacing it soon, its time is near. Temporarily I'm going to use the battery out of my plow truck which sits idle this time of year. Then I'll buy another red-top. BTW, when I took the battery out of my new Z06, I put it in my pick-up which needed a battery. A year later my truck got stuck when that battery died while doing errands. And it had been running less than five minutes previously.
Old Sep 27, 2014 | 11:50 PM
OKZ06's Avatar
OKZ06
St. Jude Donor '13-'14
I really like my red top and have had zero issues with it, but I do daily drive my car.
I have seen nearly every brand of non agm battery leak, I will not take that chance with my car.
Old Sep 28, 2014 | 12:30 AM
Cliff8928's Avatar
Cliff8928
The NAPA battery that was in my '04 was leaking when I got it. I had to repair the vacuum hose for the HVAC due to the acid leaking on it. I replaced it with the 34DT Duralast Platinum AGM from AutoZone.
I've heard that the quality of Optima batteries have went down since they were bought out and stopped being manufactured in the USA.
Old Sep 28, 2014 | 06:32 AM
Cubman's Avatar
Cubman
Old Sep 28, 2014 | 07:09 AM
usgecko's Avatar
usgecko
St. Jude Donor '13,'14
He asked for opinions, why be an *** when someone gives theirs?
Old Sep 28, 2014 | 07:43 AM
2CRUZIN's Avatar
2CRUZIN
Had the Optima Red Top in my 98 for seven years and put over 130,000 miles on it. Red Top was still strong when I sold the car. Everyone has different opinions but for me its the Optima Red Top.
Old Sep 28, 2014 | 07:48 AM
VettesGoneWild's Avatar
VettesGoneWild
I just installed a new Delco battery last March, so far so good I guess.....Sounds like a good idea to monitor your battery for potential leaks no matter what the brand. Would the battery need to be removed to see leakage in the tray or will a leak begin to fill the tray before overflowing, giving some time to catch the problem before causing ECM damage?
Old Sep 28, 2014 | 07:54 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
I have three red tops in all of my vehicles.. I've never has an issue, I've had red tops for 15 years. I have one that is ten years old... still kicking.. I have a ten year old Optima red top I use on my test bench. If I need a battery again, it will be an Optima red top.
Bill aka ET
Old Sep 28, 2014 | 08:05 AM
tcrote5516's Avatar
tcrote5516
I wasn't being an ***, I was responding to his "forget the Red Top" because of reliability statement followed by his "opinion" to put a plstic tub of acid above his ECM. He was basing his opinion on "reports of failures" and NOT ownership. FAIL. If you havent used them, don't tell me what they do. You can find a negative opinion online for ANYTHING.
I suppose I could have used softer language however it wasn't insulting. I simply stated facts.
I have purchased 4 Red top's in the last 10 years. I still have the original 10 year old battery in use. It's been in 3 different cars and is now the main starting battery for my house backup generator! (granted the generator doesn't take much juice to start but that is a 10 year old battery!)
Old Sep 28, 2014 | 08:09 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
In my experience I have found that using a conventional battery is best in our Vette's -
Optima's are good but not necessary - Expensive (Gel Cell)
Race batteries are good for weight reduction and space saving - Expensive (Dry Cell)
Conventional Batteries - Best bang for your buck and readily available - (Wet Cell)
Also in my experience, all these batteries need a "Battery Tender" if your Vette sits for a while or a long while - no matter what -
So this last time I went back to a conventional battery and all is good!
Thanks,Matt
To New Battery Recommendation
Old Sep 28, 2014 | 08:27 AM
65GGvert's Avatar
65GGvert
Here are lots of opinions, lots of reading. My opinion is just mine, these are others:
http://www.google.com/webhp?nord=1#n...p+in+C5+issues
Old Sep 28, 2014 | 12:14 PM
99 VET's Avatar
99 VET
Oldtimer
St. Jude Donor '13
I've had good service w/Red Tops. Suggest you use a battery mat b-4 the install. I also use a trickle charger (CTEK 3300) year round & yes mines a garage queen.
Old Sep 28, 2014 | 01:10 PM
sonny557's Avatar
sonny557
Been using costco battery for past couple of years, only drive a couple of times a month and always starts strong.
