Fan stopped working...Help
Old Sep 28, 2014 | 08:32 AM
harley_dude34601's Avatar
harley_dude34601
Default Fan stopped working...Help
Question guys, one of my cooling fans froze up. Do i need to order two fans, or can i order just one? All i found is two.
Old Sep 28, 2014 | 09:36 AM
65GGvert's Avatar
65GGvert
If it were my car, I'd e-mail Marc@vettenuts.net for a replacement.
Old Sep 28, 2014 | 09:38 AM
tcrote5516's Avatar
tcrote5516
Sometimes all they need is a shot of lubricant to free up. Had this happen to both fans in my 5 series BMW and it worked both times. Never had to replace them.
Old Sep 28, 2014 | 11:34 AM
lionelhutz's Avatar
lionelhutz
You can get the motors only. Rockauto has 3 different ones for you to chose from.
Old Sep 28, 2014 | 02:02 PM
jim993's Avatar
jim993
If you pull the fan shroud for repairs, I recommend that after you unclip the shroud from the radiator you slip a piece of cardboard between the shroud and radiator to protect the radiator fins while you work the shroud out. I took mine out the top.
Also, I was unable to get to all of the clips and motor plugs on the fan shroud without first unbolting the stabilizer bar hold downs. Then the stabilizer bar could be moved out of the way without unbolting the stabilizer bar end links.
Old Sep 28, 2014 | 05:49 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
I would replace both while you have it apart. I didn't; and had to pull it all apart a couple months later to replace the second unit.
To Fan stopped working...Help
