[Z06] Rev Limiter woes?
Old Jul 30, 2002 | 10:54 PM
Tom Steele's Avatar
Tom Steele
Default Rev Limiter woes?
I have a problem with the Z06 that I didn't have with my 2000 six-speed coupe. I don't seem to get the shift light warning on the HUD in time to shift before hitting the limiter now.
I realize this car is revving faster than the 2000 was, but it seems like the light should come on sooner?
Also, I - and a friend - both have a problem with our tachs keeping up. We have both tested the cars, and if you are lightly throttling the car up to red-line, the rev-limiter will come on right at red-line on the tach.
HOWEVER, under WOT, the tach seems to lag behind and you hit the rev-limiter before the tach show's red-line.
Anyone else with this problem?
Old Jul 30, 2002 | 11:09 PM
McRat's Avatar
McRat
Default Re: Rev Limiter woes? (Tom Steele)
Yep!
I had to shift at 6000 - 1/2, 6300 - 2/3, 6500 3/4.
Did tag the limiter a bit... ;)
Old Jul 30, 2002 | 11:19 PM
dbarbosa's Avatar
dbarbosa
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Rev Limiter woes? (McRat)
Same here, Bro seem to blip the limiter.
It does climb fast....
Darwin.
Old Jul 31, 2002 | 08:38 AM
169mph's Avatar
169mph
Default Re: Rev Limiter woes? (dbarbosa)
I have the same problem!
Mike
Old Jul 31, 2002 | 12:10 PM
gotto41's Avatar
gotto41
Default Re: Rev Limiter woes? (169mph)
Sounds like a warranty issue. Take it in and tell the dealer it rev's too fast.
What do you think the rev time is in 1st between 6300 and the limiter!
Old Jul 31, 2002 | 01:10 PM
Tom Steele's Avatar
Tom Steele
Default Re: Rev Limiter woes? (gotto41)
Yeah, but you would think GM would have thought of this too, and they could have set the SHIFT light to come on a little earlier in first gear...
As it is now, it is very near useless.
Old Jul 31, 2002 | 01:16 PM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
You shift with the HUD tach? :confused:
That thing is just way to small and inaccurate. I turn off my HUD when racing at the track.
Old Jul 31, 2002 | 04:55 PM
Tom Steele's Avatar
Tom Steele
Default Re: Rev Limiter woes? (rbartick)
No!
I only use the HUD for MPH. But there is a SHIFT light that comes on when you near redline. I DID use that for my 2000 coupe, because it came on early enough that it was useful.
With the Z06, it doesn't come on early enough in 1st and 2nd gear and I still hit the limiter!
Old Jul 31, 2002 | 05:24 PM
RussBt's Avatar
RussBt
I've never seen that come on in my car, except in really bright direct sunlight. ;)
I always watch the analog tach when running hard.
--rb--
Old Jul 31, 2002 | 07:07 PM
Steve Row's Avatar
Steve Row
Cruise-In II Veteran
Cruise-In III Veteran
I don't use the Shift light on the HUD either. In fact I don't use the HUD much at all. I did see it come on once after someone on the forum mentioned it.
My tach lagged terribly when the car was new. But as the car broke in, so did the tach. Works fine now and has since about 1000 miles on the car.
Old Jul 31, 2002 | 08:21 PM
Tom Steele's Avatar
Tom Steele
Ross,
I'm gonna have to go back to the tach I guess. I always liked just using the HUD shift light on my 2000 coupe. I didn't have to take my eye off the road (err, track that is...) and could concentrate on my surroundings more.
Unlike the old 5.0's that I was used to before, which began to fall off in hp LONG BEFORE the rev-limiter would kick in, the C5's (LS-1 AND LS-6) both pull hard straight to the limiter. I need to program another 200 rpms into my CPU.
However, I have also been seeing my TACH lag in lower gears, so even IT isn't doing the job properly for me. I'm going to have to start experimenting and seeing what the highest rpm (INDICATED) I can shift at in each gear.
Someone in this thread posted some good starting points to experiment with...
Or, I suppose I could buy a nice aftermarket tach with a shift light. Anyone have any suggestions?
Old Jul 31, 2002 | 08:22 PM
Tom Steele's Avatar
Tom Steele
Default Re: Rev Limiter woes? (Steve Row)
That's STRANGE. The tach shouldn't break in, but perhaps the computer learns something? I have almost three times your mileage though, and so does my friend...
To Rev Limiter woes?
