LS3/LS2 Stroker combos
Old Oct 3, 2014 | 08:05 AM
ZZ06's Avatar
ZZ06
Default LS3/LS2 Stroker combos
Im interested to see some of the LS3 or LS2 stroker combos out there. Anything from mild to wild. Im excited to see what my own combo will lay down. Although my completion date has been pushed due to land lords wanting to sell the house my wife and kids are in. Anyway lets see em!!!
TSP 418
Weisco -4cc pistons
4.080 bore
Callies 6.125 rods
Callies 4.000 crank
Cometic 0.051 gaskets
11:5.1 CR
EPS Custom 240/248 .6XX .6XX??116lsa (dont rememer the entire specs. will look once home. im currently deployed)
LS7 Lifters
42lb injectors
SDCP blue printed oil pump
FAST 92 (not ported)
LS2 90mm TB (not ported)
TEA 243's Stage 2s (ported obviously)
1 3/4 LG Street headers
Halltech Venom Intake
SLP UD Pulley
Corsa Xtreme's
Im hoping to crest the 500rwhp mark
Old Oct 3, 2014 | 12:14 PM
Last C5's Avatar
Last C5
I think you should make that pretty easily. I just installed a CNC Motorsports LS2 408 Stroker motor and it made 520 rwhp and 500 torque.
CNC 408
Diamond -3 flat top pistons
4.030 Bore
Eagle H Beam Rods
Eagle Forged Crank
Factory Gasket
11.5.1 Compression
BTR Stage 3 Cam 235/242 620/593 111 lsa
Morel Lifters
42 lb Flow matched injectors
Melling High Volume Oil Pump
Fast 102 Not Ported
Nick Williams 102 Throttle body
AFR 230 heads milled to 67mm
Dynamax 1 3/4 headers
Halltech CAI
ATI 25% Underdrive Pulley
Borla Cat backs
Jesel Rockers
Old Oct 3, 2014 | 01:42 PM
ZZ06's Avatar
ZZ06
Very nice out of that 408!
Come on guys i know there are plenty more strokers out there!
Old Oct 3, 2014 | 04:34 PM
jcsperson's Avatar
jcsperson
NC Events Coordinator
My 416 LS3 ERL stroker has:
Callies Compstar/Wiseco internals
11.2-1 compression ratio
FAST 92mm intake
60 lb. injectors
Trickflow 235cc heads
234/238 .602/.604 112 LSA cam
Yellow Terra 1.7 rockers
AR long-tube headers and X-pipe
Kooks Hi-flow cats
C5Z Ti catback
It made 524 rwhp and 490 fptq.
Old Oct 3, 2014 | 07:52 PM
WKMCD's Avatar
WKMCD
Grab a cold one and read this. This is a 5 year project build starting with an LS2 block, 4 inch crank and L92/LS3 heads. It was the first in the country and is well chronicled from the beginning to refurbishing into a 427. Always mild. The 403 made 530 and the 427 made 577/530 at the wheels.
http://ls1tech.com/forums/generation...b-c-d-e-f.html
Unfortunately, the car was totaled last December but the engine was untouched and is going into a C3 resto-rod.
Old Oct 4, 2014 | 08:53 AM
ZZ06's Avatar
ZZ06
Keep em coming! Some sweet builds!
Old Oct 4, 2014 | 08:56 AM
ZZ06's Avatar
ZZ06
WKMCD i will read that one when time allows. Wow that is long
Old Oct 4, 2014 | 09:34 AM
Pete W's Avatar
Pete W
I too really like to see all the different builds and what parts people are using. Not to mention seeing what HP they are making. What kind of costs are you guys looking at for these builds? Is it cheaper to accumulate on your own, or buy a shortblock/longblock assembly from TSP/scoggin dickey or whoever? I am am starting to save for a forged block and want some more cubic inches, 427 preferred.
WKMCD did you ever give the complete cam specs in that post? I read it recently and don't remember seeing it anywhere. Your motor makes amazing power for something that is not an all out build. I really like it.
Old Oct 4, 2014 | 01:06 PM
WKMCD's Avatar
WKMCD
We tried a lot of cams but the best for the 403 build was a 230-240 - 111 lsa with .660 lift on both sides. The best on the 427 was a 234-242 with .643 lift, 113+2 lsa. Small cams for the displacement. Scaled to a 346 build, they would be in the 224 or smaller range.
My one requirement of the cams were excellent drivability. Great average power was a by-product of having the right people involved.
Old Oct 4, 2014 | 04:10 PM
TXGS507's Avatar
TXGS507
560/535 out of my LS2 based 414ci.....
Old Oct 10, 2014 | 04:26 PM
ZZ06's Avatar
ZZ06
^^^ Awesome builds guys.
keep em comin!!!
Old Oct 11, 2014 | 01:29 PM
04tripleblkcoupe's Avatar
04tripleblkcoupe
TSP 408 4 inch intake tube and 11.3.1 comp. 520rwhp 496tq conservative tune
Callies Compstar Crank 4340 4.00" ARP Main Bolts
Rods 6.125 ARP bolts
Pistons 4.030 -3cc
247cc PRC ported heads
Spring Kit Rated To .675" Lift
68cc CNC Machined Chambers
2.120" Intake / 1.600" Stainless Valve
Hyd Roller Cam 239/242 .649/.610 111.5 LSA
Comp Roller Rockers Arm Ultra Gold 1.72
7.450 Chromemoly Pushrods
Nick Williams 102 TB
Fast 102 Intake
Fast Fuel Rails 60lbs injectors
4L65E Level V RPM tran
Yank SS4000 Stall
Stage II differential, C6 Z06 left and right axles, micropolished gears, HD clutches and springs,
gear ratio: 3.42
Last edited by 04tripleblkcoupe; Oct 11, 2014 at 01:40 PM. Reason: added description
Old Oct 11, 2014 | 02:40 PM
ZZ06's Avatar
ZZ06
Pistons 4.030 -3cc
Fast 102 Intake
Yank SS4000 Stall
gear ratio: 3.42
That's impressive through that stall. Clean lookin motor
Old Oct 11, 2014 | 05:04 PM
04tripleblkcoupe
that was at 5500 rpm. and by the way I have some friends that live in your city.
Old Oct 12, 2014 | 11:29 AM
ZZ06's Avatar
ZZ06
Oh yea? Maybe you can point me in the right direction.
Old Dec 17, 2014 | 08:52 PM
540i 6spd's Avatar
540i 6spd
CNC 408
4.030 Bore
Eagle H Beam Rods
Eagle Forged Crank
Factory Gasket
11.5.1 Compression
Morel Lifters
Fast 102 Not Ported
Halltech CAI
Borla Cat backs
Jesel Rockers
How is the drive ability with this cam?
Old Dec 18, 2014 | 12:37 AM
C5Natie's Avatar
C5Natie
500rwhp should be quite easy for you. My stock LS3 with only a TSP 231/236 cam and headers put down 470/455 so 500 should be a cake walk.
Old Dec 18, 2014 | 12:48 AM
Last C5's Avatar
Last C5
The cam will lope a little bit driving through the pits at slow speeds in second gear. Other than that, it seems fine even with the ultra light flywheel/clutch set up that I have on it.
To LS3/LS2 Stroker combos
