Help
Old Oct 5, 2014 | 08:45 PM
Dave concrete's Avatar
Dave concrete
Default Help
So tonight on the way home car was running fine then 5 minutes from my house car just dies. Zero pressure on gauge. Just in case I put in two gallons to verify fuel gauge is good didn't help, checked fuses and relay they check out fine. So could it be the fuel pump? Anyway of checking without dropping tanks? Car has 26k on it and fuel pump was replaced thru warranty on crossover repair so maybe 5k on it.
Old Oct 6, 2014 | 03:21 PM
corvettebob1's Avatar
corvettebob1
Check the ground for the fuel pump on the frame first.
Old Oct 6, 2014 | 06:44 PM
Dave concrete
So I started checking things and found my BAP fuse was blown. Changed fuse blew again. Now what?
Old Oct 6, 2014 | 08:30 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
Find where the wire is grounding at and fix it
Old Oct 6, 2014 | 08:52 PM
Dave concrete
Yeah tomorrow I will trace where it's going looks like under battery
Old Oct 7, 2014 | 12:05 AM
Jackman's Avatar
Jackman
First time today I had this problem with my 2003. Tried pulling it out of garage and as soon as I let up the clutch the car stalled. I did this several times and eventually got my car out of the garage and it was rolling down my driveway. It would start and idle but if I put it in gear and let up the clutch it just stalls. I managed to get the car back into the garage but at this point I have an expensive dust collector that I can't drive. Any suggestions out there???
Old Oct 7, 2014 | 10:49 AM
Jackman's Avatar
Jackman
Originally Posted by 8VETTE7
Certainly sounds like the 2mph Column Lock fuel shutoff. What message(s) are displayed in the DIC???
Suggest you open your own thread with your problem instead of hi-jacking this one.
Thanks for the advice.
Old Oct 7, 2014 | 07:26 PM
Dave concrete
after a few tests and talking to Chris @ ECS we feel it's the MSD BAP so ordered a new ECS model.
To Help
