Not just the headlights being the only variable. The increased demand on the alternator from the headlights and interior dash lighting increases drag on the motor and takes up hp as well.
Yeah they certainly are unaerodynamic when they're up.
However, with the headlights down, the C5 is the most aerodynamic corvette ever made, so there's that.
Also, a key advantage to pop-up headlights was that the nose could be lower and longer. The C6 has a more abrupt nose, because the headlights have to be a certain height by regulation, and if they're not pop-up, than the nose has to be taller to accommodate the higher height. The lower and more sloped nose of the C5 probably helps it be more aerodynamic than a C6.
I think eventually the "streamlined" headlights took hold aethetically, but the main killer of pop-up headlights is that in Europe, cars have to meet "pedestrian safety" criteria, along with other normal safety tests. The pedestrian safety criteria basically measures how likely a car is to hurt a pedestrian by hitting one at certain speeds. Essentially, pop-up headlights couldn't realistically meet this standard. I believe the standard started taking effect in 2004, hence no production car made since 2004 has had pop-up headlights.
We were driving very flat US 50 across southern IL labor day weekend with the top down in our vert and when I turned the headlights on we could feel a difference in the airflow in the passenger compartment. I turned them back off and then back on again to confirm what we were feeling was indeed due to the headlights' affect on the car's aerodynamics.
Seems to be the most logical conclusion is the cumulative affect of air temp(dense air will burn a little more fuel), alternator drag AND the lights up creating a little more drag at 75 mph. As stated before terrain and wind were non factors as no significant terrain variations in either direction and there was MORE breeze in the daytime,,almost dead calm on the way home.
You may not notice the terrain, but a difference of a few hundred feet from start to end could make a big difference. Probably wouldn't even take that much altitude variation impact mpg. Gravity's a.....
Also possible your daytime wind we'd a tailwind which you list at night. Most of the time predominant winds are consistent, so your results would also be consistent.
I notice that I get better mileage driving home from work that to work. (About 17 miles.) My elevation cell phone app on my phone shows home to be about 150' lower than work. I've also noticed the same thing on a longer drive to a nearby town that is about 200' higher than home. If not for that app I would have guessed half or less of that elevation change.
