12 disc CD changer
Old Oct 27, 2014 | 10:43 PM
thisMSGgood4me's Avatar
thisMSGgood4me
Originally Posted by RichardDomenick
Where do I find a Double D Mod for 80 bucks? I've goggled to no avail?
Call me at 810-343-9055 Dick72958@yahoo.com
For those who have a cd changer in the trunk!
http://shop.doubledmods.com/Peripher...?categoryId=-1
For those who do not have a cd changer in the trunk!
Old Jun 18, 2021 | 07:45 PM
kelalex's Avatar
kelalex
Hi I know this is an older thread but... Double D mods doesn't seem to still be in business. Is there somewhere else I could get a converter like the ones they mention? Thanks!
Old Jul 22, 2022 | 09:27 PM
Proudlion63's Avatar
Proudlion63
1st Gear
Default 12 disc cd changer
Originally Posted by thirdonebest
Hey folks, I have a '98 convertible with a 12 disc CD changer and it has started giving trouble. It appears to be in the loading/unloading system. It wouldn't load the CD back into the tray and loaded the next one into the player. I would have retrieve the CDs manually. Now it has quit completely. Would like to get it fixed, does anyone now a reputable place to get it repaired? Or am I better off to replace it? Bear in mind I want to use the stock mounting with no modification. Thanks
Hi guys, I had the same problem with my cd changer. I sprayed a little bit of WD40 on the actuator arm and cleaned the residue off with a small cloth and it worked just fine. Be careful not to spray too much.
Old Jul 23, 2022 | 03:30 PM
JMG2's Avatar
JMG2
Moderator
zombie thread alert...
Old Mar 12, 2023 | 05:23 PM
806-Corvette's Avatar
806-Corvette
Where is the actuator arm? I just bought my original C5 back from the guy that bought it from me 13 years ago. Now the 12 Disk CD player in the rear of my Coup will load the CDs. Sure, lots of options. Just trying to get the C5 working again.
Last edited by 806-Corvette; Mar 12, 2023 at 05:25 PM. Reason: Additional context.
Old Oct 5, 2023 | 10:58 PM
TazmanianD's Avatar
TazmanianD
Folks,
just to help out.
My 12 Disc Changer was giving me - Err, on the screen when I tried to use it.
I disconnected the power cable directly attached to the Player from the trunk.
I then unmounted from the vertical stand - 6 screws.
Cleaned each CD holder within the magazine.
Cleaned all the CDs and anywhere else I could - still did not work.
Then, sat the player upright and plugged the cable back in.
Turned on the ignition and the player got going.
After a few tries - it popped out a CD - which was stuck within the player (not the magazine). It did pop out and at sat in the 12th CD location.
Hmmmm, interesting.
I mounted the Player back
Plugged the cable - and it's been going ok now for about 2 weeks.
Hope this helps.
Old Oct 7, 2023 | 09:33 PM
JMG2's Avatar
JMG2
Moderator
guys, thread is 9 years old, pretty sure he's either resolved the issue or moved on.
Old Oct 7, 2023 | 11:07 PM
Closed.
