Passenger headlight not working
Old Oct 20, 2014 | 10:29 PM
Galler's Avatar
Galler
Default Passenger headlight not working
Hey guys. So I was out tonight. Everything working just fine. Then as I got in my 99 FRC and started it up flipped the headlights much to my dismay the passenger side didn't open. The light is on but it didn't open.
Like I said the light is on, but the lid doesn't lift. I will note that the motor is spinning but the lid isn't opening.
Thoughts? Gears? I replaced driver side with brass and the seller I bought it from two years ago said he had replaced the passenger side. Who knows if that's true though
Old Oct 20, 2014 | 10:35 PM
rock_man's Avatar
rock_man
Try raising the the headlight using the manual method. If that doesn't work, it's the gear. If it works, there's something else amiss.
Old Oct 20, 2014 | 11:02 PM
Galler's Avatar
Galler
So dumb question maybe but is **** the star pattern on the back of the headlight motor?
If not how do I manually raise the lid?
Old Oct 20, 2014 | 11:09 PM
rock_man's Avatar
rock_man
Yes, they normally have a plastic protection sleeve over top. Remove the sleeve and turn the wheel underneath.
Old Oct 20, 2014 | 11:15 PM
Galler's Avatar
Galler
So here's what happens if I spin the wheel alone. It will not open. If I grab and lift the headlight up, and then spin the wheel it will stay up
Old Oct 20, 2014 | 11:37 PM
Galler's Avatar
Galler
Does this mean it needs a new gear?
To Passenger headlight not working
