Tires
Old Oct 22, 2014 | 07:05 PM
SuperVetteC5's Avatar
SuperVetteC5
Default Tires
I have a C5 Z06 that is supercharged, around 600hp. I'm having trouble making it hook up good when I get on it. What are some good choices for rear tires that are drivable on the street and hook up well. Thanks for your input.
Old Oct 27, 2014 | 12:51 AM
tcruse's Avatar
tcruse
I had some 305/35/18 mickeys that weren't bad when I was at that power level. I would try those of maybe some 295/45/17 mickeys. Which supercharger kit do you have
Old Oct 27, 2014 | 12:54 AM
CQRT's Avatar
CQRT
Nitto drag radials...do a search on them...they should work just fine.
Old Oct 27, 2014 | 08:35 AM
SuperVetteC5
I have the A&A kit installed. It was on the dyno at 567 hp to the rear wheels. My intro said Borla exhaust but I have a full Corsa Exhaust, long tube headers.
SuperVetteC5
Are those Mickeys runflats?
Old Oct 27, 2014 | 08:44 AM
Maxx_Z06's Avatar
Maxx_Z06
C5 COTM Coordinator
Toyo R888's.
Old Oct 27, 2014 | 01:47 PM
tcruse's Avatar
tcruse
Mickeys are DR's. Also like Maxx said toyo r888's will get it done also and you'll still be able to handle with that tire
Old Oct 27, 2014 | 02:34 PM
Maxx_Z06's Avatar
Maxx_Z06
C5 COTM Coordinator
Old Oct 27, 2014 | 04:13 PM
Laser Guided's Avatar
Laser Guided
Another nod for the r888 by toyo. They have awesome grip to put the power down (100 treadwear rating) and a stiff sidewall so they handle well in corners. Because of the sidewalls, they are considered "roadcourse radials", which imo is better for corvettes unless you specifically use it as a drag car (in which case the nitto drag radials which people mentioned earlier would be ideal)
Old Oct 27, 2014 | 04:28 PM
SuperVetteC5
Thanks guys, appreciate the info. Got to be able to outrun my son you know. We both have supercharged C5s. His is a 2003 50th Anniversary with 27K miles, mine is a 2004 Commemorative Edition with 12K miles.
By the way, you think the 305/30/18 would be the way to go?
Old Oct 27, 2014 | 04:36 PM
Maxx_Z06's Avatar
Maxx_Z06
C5 COTM Coordinator
That's a good way to look at it.
Nice father-son competition. Hopefully its something my son and I can share once he grows up.
R888's are unfortunately not made in a 305/30/18 but a 305/35/18 and a 295/30/18 are available. The 305's R888's run pretty wide, i had them on my 19x11 inch wheel on my previous setup.
Old Oct 27, 2014 | 06:04 PM
tcruse's Avatar
tcruse
Your son have the widebody kit on his car
Old Oct 27, 2014 | 07:45 PM
SuperVetteC5
No he doesn't.
To Tires
