Pressure test leaks
Old Oct 23, 2014 | 07:25 PM
SCvette1's Avatar
SCvette1
Default Pressure test leaks
Have any of you dealt with this problem? Took my 99 vert to local shop to get trans flush, new filter, fluid , gasket, etc ( had a gasket leak needed fixing). While on lift and looking around also noticed small leak at the nipple of the overflow reservoir. Did a pressure test and also saw where there was a small leak in radiator ( where hose connects to top of radiator, all plastic). Mechanic recommended new radiator and reservoir. Mechanic advised if I didn't address this now it could blow out and cause overheat/engine issue. He also said if I didn't want to fix everything now, he strongly recommended fixing coolant leaks before trans fluid. He tried new clamp but didn't work. He said the nipple connector had a crack, just as the radiator did. Quote to do transmission flush, new radiator and new tank, hoses, and clamps, with labor about a grand. Is this reasonable or am I getting the shaft....without the lube?!!!
Old Oct 23, 2014 | 08:03 PM
JR-01's Avatar
JR-01
I would say it's in the ballpark.......... maybe a couple hundred either way. Dealer or independent shop?
Old Oct 23, 2014 | 08:04 PM
SCvette1's Avatar
SCvette1
Independent
Old Oct 23, 2014 | 08:12 PM
JR-01's Avatar
JR-01
$500 for radiator, $200 for tranny flush, $300 for tank, hoses etc. Check around if you don't trust the guy.
Old Oct 23, 2014 | 08:55 PM
SCvette1's Avatar
SCvette1
To Pressure test leaks
