[Z06] 01z tranny issue
Old Oct 27, 2014 | 10:44 PM
slow01z06's Avatar
slow01z06
Default 01z tranny issue
Ok guys, so a few weeks ago I installed my new mgw shifter and was amazed at the improvement it made over the b&m the previous owner had in it. But after driving the car more I started to notice a grind on the 1-2 shift during spirited driving. At first I thought it could be me not being used to the shifter, but after deliberately shifting and making sure the clutch was fully disengaged it still will grind on a hard 1-2 shift at high rpm. During normal driving it is fine, and on a 3-2 downshift it goes in without a fuss. If I granny shift it into 2nd at high rpm it seems to lessen/eliminate the grinding issue. It won't lock me out of 2nd, just grinds on the way in. Any ideas?? I've done some searching and it could be a few different things. I've heard possibly the synchro/shift fork. Or possibly a blocker ring. Just looking for some more insight before I drop the trans and have it rebuilt. Any insight would be appreciated!
Old Oct 27, 2014 | 10:55 PM
Breze84's Avatar
Breze84
I would check to make sure you installed the shifter properly if you didn't have the problem previous to the MGW. I would check the following
Shifter adjustment
Damaged syncros
Damaged gears
Fluid Type "If you changed it"
Also I have heard of the MGW shifter causing grinding in the past when out of alignment!!! Food for thought
Old Oct 27, 2014 | 11:04 PM
slow01z06's Avatar
slow01z06
I talked to George over at mgw. He said if it's grinding whole going in gear it's probably trans related. I installed the shifter exactly how the instructions called for to the T, so who knows. Might try to pull and reinstall it first. Start with the simple things right?
To 01z tranny issue
