Techron at COSCO
Nov 12, 2014 | 02:40 PM
Techron at COSCO
Techron on sale for $12.99 for six 16 oz bottles. Enough to treat 16 gallons of fuel per 16 oz bottle. If this is a repost --please over look it.
Nov 12, 2014 | 03:45 PM
Are you sure that is the same Techron Plus everyone else sells for 6 bucks a bottle?
Nov 12, 2014 | 04:05 PM
it isn't
but i'm also not sure what's different in the formula, could be the same, could not be
Nov 12, 2014 | 04:48 PM
Quote:
Originally Posted by
racebum
it isn't
It would be nice to know if it's the real deal and will help with the fuel gauge problems or if it's a waste of money no matter how cheap it is.
Nov 12, 2014 | 04:57 PM
Chevron Techron Fuel Injection Cleaner, 6/16 oz
Item # 847202 $23.52 Thats the info I see online
Nov 12, 2014 | 05:07 PM
Smoken1
That's not the right stuff.
Nov 12, 2014 | 06:26 PM
IT is not the plus but will work just fine. I buy it and use it.
Nov 12, 2014 | 06:37 PM
FRANK J CARCIA
I have read in several places that it is not the same and does not work just fine for cleaning the contacts in the fuel sender.
Nov 12, 2014 | 06:43 PM
I believe that Chevron has pulled a fast one. This is the old "Pro Guard" re badged as TECHRON. Looking at the bottle, there is no part nbr for comparison with the other Techron products such as the "New techron 65740". The good news is that it works but not quite as good. And is half the advertised price on Amazon.
Nov 12, 2014 | 06:53 PM
JR-01
Don't believe everything you read. Again, I have used it and has helped. I'll repeat it is not the same as the plus but has helped!!!!!
Nov 12, 2014 | 06:59 PM
FRANK J CARCIA
Helped what?
Did you have fuel gauge problems and it cured them?
Nov 12, 2014 | 07:08 PM
JR-01
Helped what?
Yes sir i have and yes sir it has Cured them. I have owned this car 16 years and have the going to empty problem the gas gage not working, And I'm hear today to tell you i do not have those problems as we speak, Mostly because of that product. Believe it or not. Try it you might like it.
Nov 12, 2014 | 07:13 PM
FRANK J CARCIA
That's what I wanted to hear.
Nov 12, 2014 | 09:38 PM
Smoken1
If the product works, then that is a good price. Too bad there is no Costco around here.
Nov 13, 2014 | 01:17 PM
What about Berryman's B12 Chemtool? Does anybody use that and how is it different from Techron? It works wonders in my bikes and lawnmowers and outboards to keep carbs clean if stored for extended times without use. And that stuff is only about $2.89/can compared to Seafoam which is $9.99/can and it works much better.
Nov 13, 2014 | 01:31 PM
Well there's also Advance A.P..... the have the Techron brand and the STP brand BOGO sale right now as well.
Nov 13, 2014 | 11:50 PM
At least two diffrent products
There is Fuel INJECTOR cleaner
and then there is Fuel SYSTEM cleaner.
Fuel SYSTEM cleaner is multipurpose and contains alcohol to absorb any water in the gas. It contains SOME injector cleaner.
