Headlights
Old Nov 12, 2014 | 10:52 PM
2FAS4UU's Avatar
2FAS4UU
Default Headlights
I know this is a beaten subject, but I have to ask! Does anyone share the same problem with adjusting the low beams to the correct adjustment, then turning on your high beams and find that there aiming at the moon. It bugs the crap out of me, so is this a typical C5 issue. I want so badly to install projectors, but can't afford them right now.
Old Nov 12, 2014 | 11:05 PM
Here is a write-up that discusses aiming the C5 headlights. Might give you some ideas and make the job easier.
File Type: doc
Old Nov 13, 2014 | 08:17 AM
MAC5's Avatar
MAC5
Bulbs improperly seated in the sockets is most often the problem when the high beams are that misaligned. One or two of the bulbs tabs are not aligned and pressed into the socket properly when the bulb is rotated to secure it.
To Headlights
