[Z06] Dd cam c5 z06??
Old Nov 14, 2014 | 10:59 AM
zdeckich's Avatar
zdeckich
2017 Corvette of Year Finalist
2016 C5 of the Year
Default Dd cam c5 z06??
Anyone here have a daily driver C5 Z thats cammed? How ofton do you need to change the springs, or get it retuned etc. Please let me know your experinces with it. Looking at a few cames from LG and 21st century muscle cars. Thanks for your input.
Old Nov 14, 2014 | 12:23 PM
92mr2turbo's Avatar
92mr2turbo
I have/had a 2000 FRC with 243 heads, ud pulley, forged bottom with a comp cam 224/230 .588/.592 114LSA. It had excellent street manners on the stock 3.42 gears and a little chop you could hear since I had headers, cats and exhaust. Never stalled or surged and had 1 tune only. I drove the car 15K miles in 2 years before the cam was pitted and the bottom end bearings were starting to wear prematurely(Builder Error). I bought Pac 1518 springs and didn't have any issues. Car made 404/380 sae. The car still drove fine when I dropped it off at a new shop and probably could have made another 10-15 k miles on that setup. My oil pressure was still about 30psi+ at idle. I did have a new oil pump, lifters, push rods, etc installed when the cam went in back in 2011.
As far as your cam choice, I would do more searching and get some insight on what others have done or currently using. The current cam I just purchased has a different grade of steel than the last cam I had. I do plan on commuting 15-20k miles a year when I get the car back from current builder so hopefully as a DD I can do at least 30-40k between spring changes. hth
Old Nov 14, 2014 | 12:57 PM
Sales@Texas-Speed's Avatar
Sales@Texas-Speed
Premium Supporting Vendor
If want something extremely friendly we also have a 228/228 that makes an awesome daily.
I also had 30k on our 233/239 .595/.605 112lsa with .650 double springs, when I got rid of the car, and it was still going strong. It drives pretty nicely in my opinion and makes good power as well.
Old Nov 14, 2014 | 03:08 PM
zeevette's Avatar
zeevette
It'd be helpful to list your other mods, and performance goals, in your inquiry.
Old Nov 14, 2014 | 07:31 PM
zdeckich's Avatar
zdeckich
2016 C5 of the Year
headers, catless mid, CAI ported TB.
Old Nov 15, 2014 | 05:33 PM
Dave02C5's Avatar
Dave02C5
my BTR stg 3 NA cam 231/242 - .617/.592 - 112+2 LSA is good as a DD and its fairly aggressive.
Old Nov 18, 2014 | 01:09 AM
dagon138's Avatar
dagon138
That's your DD cam?
Old Nov 18, 2014 | 01:58 AM
808EB03Z06's Avatar
808EB03Z06
This is the Texas Speed 233/239 cam on a 112 with ARH headers and Y, and the stock Ti's. I daily drive this and run auto-x with it.
Old Nov 18, 2014 | 02:27 AM
AirborneZ06's Avatar
AirborneZ06
I 2nd this! I had this very same cam from Texas Speed and it was great:ia gree:
Old Nov 18, 2014 | 09:28 AM
ZF Six's Avatar
ZF Six
This isn't a direct answer to your question, but I had an LS1 Camaro years ago and put a 224/228 ~.585" lift 114lsa cam in it and it very nearly drove like stock. No surging or bucking and had a great powerband.
Old Nov 18, 2014 | 09:29 AM
ZF Six's Avatar
ZF Six
I think the spring change will depend on what springs you put in it and how hard you drive it. I don't see why you would ever need to get it retuned unless you made a change.
Old Nov 18, 2014 | 12:40 PM
zeevette's Avatar
zeevette
I've long championed smaller cams, for being more tunable, less smelly, and just as powerful in most situations. I did heads at the same time as my first cam, so I optimized my choice of cams to match. With only a 228-232 @112 cam, and almost every NA mod, it produced 483/432 SAE. It drove like stock, but didn't sound stock.
Old Nov 18, 2014 | 05:54 PM
zdeckich's Avatar
zdeckich
2016 C5 of the Year
That sounds really good. Im wanting that for sure sounds like its cammed. I don't mind if it has a little buck to it. I only drive about 10 miles a day.
Old Nov 18, 2014 | 06:05 PM
Sales@Texas-Speed
That's my personal favorite all around cam for an ls1. Drives really nicely, sounds awesome and makes good power.
Old Nov 18, 2014 | 06:18 PM
z06Maniac's Avatar
z06Maniac
I'm running a Texas Speed (Comp Cams) Torquer V2. It's 232/234 duration, .595"/.598 lift with 112 LSA. It has a nice lope. Makes great power with stock heads, long tube headers, and CAI. My car put down 407 HP to the tires on a conservative dyno. Pretty good street manners, but not as tame as the stock cam. With the stock cam I could run 6th gear at 45 MPH. With the V2 you will run 1 gear lower than you used to with stock. As a result you will burn more fuel and use more oil. My tuner recommended changing valve springs every 4K miles. I'm running dual coil springs. On the other hand it makes a whole lot more power than the stock cam. In general, I love the cam. It was pretty much exactly what I wanted. Heavy traffic can be a drag so, I avoid that situation when I can.
Good luck!
Old Nov 18, 2014 | 06:23 PM
Sales@Texas-Speed
Im not sure if that was a typo or not, but there is no reason to have to swap your springs every oil change. I have to assume it's a typo. I hope so anyway.
Old Nov 18, 2014 | 06:30 PM
z06Maniac's Avatar
z06Maniac
Ha! It's been a while since I did the cam.. Now that you mention it I am questioning that myself. 4K Does sound way too soon. Seems like it should be more like 20K... I will have to look my friend for a reminder. What do you guys recommend? BTW... I love the cam!
Bill
To Dd cam c5 z06??
Old Nov 18, 2014 | 06:36 PM
Sales@Texas-Speed
Bill
Checking them around 15-20k is much more realistic. Even then, that cam isn't crazy aggressive and may go farther depending on how it's used for that mileage.
Old Nov 19, 2014 | 09:20 PM
nullpointer's Avatar
nullpointer
I dd'd mine with a 231/236 cam, no issues. Spring life will depend on the cam.
Old Nov 19, 2014 | 10:12 PM
REDZED2's Avatar
REDZED2
Back in the day (C5Z days) a true daily driver cam... I mean no one would go above 230ish @ .050.. times have changed. Personally I wouldn't go above 230-232 on a 113-114 if lots of daily miles are driven. Minimal gains with stock 243's the bigger you go. Now if you're going more for just the "cam" sound, it's a different game entirely.
