Puny oil filter?
Old Nov 16, 2014 | 05:24 PM
jjc508520's Avatar
jjc508520
Default Puny oil filter?
Just did my first oil change since buying my FRC - the stuff that came out looked like crap and it had a Sams club filter - glad I did the deed. I was shocked that for a 'performance motor' the filter was no bigger than what's in my 4runner - what gives?
Old Nov 16, 2014 | 05:30 PM
SG Lou's Avatar
SG Lou
Yeah, those PF-46's are small....ground clearance I guess ?
Old Nov 16, 2014 | 06:05 PM
JR-01's Avatar
JR-01
I would be more concerned about the oil looking like crap.
Old Nov 16, 2014 | 06:45 PM
StingrayRebel's Avatar
StingrayRebel
... I prefer wix or factory gm filters... you might take a peek under one of the valve covers to see what kind of condition the inside of the motor is in... you would be surprised how many people really don't take good care of these cars
Old Nov 16, 2014 | 06:55 PM
sfc rick's Avatar
sfc rick
I've seen some pretty messed up engines in my lifetime of rebuilding them when a customer complains about them....not realizing it's all their own fault. I've had to clean the "varnish" out, to full blown oil MUD build up so thick it made itself into modeling clay.
Sad to know there are car owners so oblivious to why they need to change it frequently.
Old Nov 16, 2014 | 07:04 PM
JR-01's Avatar
JR-01
http://www.amsoil.com/shop/by-produc...mission-flush/
Old Nov 16, 2014 | 11:39 PM
I think that would be a very good guess. The OEM filter seems to do a good job - at least that's been my observation.
Old Nov 16, 2014 | 11:47 PM
bikeriderga's Avatar
bikeriderga
I would highly recommend that the OP do this and change it again after <1000 miles.
If the old oil was crud, ca bet that crud is in the engine. Run the new oil for a while, drain it, and flush it with something like the Amsoil flush as pictured here. It will not clean the engine, but will make it in much better than it is now.
Afterwards use only a high quality synthetic. I always use Amsoil. Mobile 1 is good as well.
Old Nov 17, 2014 | 01:58 AM
SG Lou's Avatar
SG Lou
OEM is all i ever used
Old Nov 17, 2014 | 11:40 AM
jackthelad's Avatar
jackthelad
NAPA "Gold" filters are Wix, fyi - even use the same numbering system. I use either those or the Mobil 1 filter.
Using an engine flush is a good idea if things are crudded up. You may have to run through a couple of cycles. If it's really messed up, in all probability the oil filter is clogged, so put on a new filter, then run the flush cycle, then drain, another new filter and repeat the whole process after a few hundred miles.
Old Nov 17, 2014 | 02:17 PM
jjc508520's Avatar
jjc508520
The car did sit on the dealers lot for 90 days - age could have something to do the condition of the oil. I will monitor the clean stuff to see how quickly it gets dirty. Thanks for the link to the Amsoil motor flush.
Old Nov 17, 2014 | 03:14 PM
stu12dozen's Avatar
stu12dozen
It's not how big it is, it's how you use it. Change your oil & filter at the recommended intervals.
Old Nov 17, 2014 | 04:51 PM
cessna10's Avatar
cessna10
cesssna10
I know its really ridiculously old fashioned
but i am still a 3000 mile oil change guy. Cant get it
out of my system going back to 55 chevy pickup
in the 60's
Old Nov 17, 2014 | 04:59 PM
JR-01's Avatar
JR-01
in the 60's
Synthetic oil can go a lot further than 3000 miles. You know you are just wasting money, right.
Old Nov 17, 2014 | 05:13 PM
c4cruiser's Avatar
c4cruiser
Some of the filters that are stocked in our shop are half the size of a PF46. The smallest one I've seen looks like it would hold only about 6 ounces. Kinda makes me wonder if some of those tiny ones are really worth having a filter....
Old Nov 18, 2014 | 09:15 AM
cessna10's Avatar
cessna10
cesssna10
I only do about 4000 miles per year so I would change
it after a year even if it is synthetic
Old Nov 18, 2014 | 10:37 AM
JR-01's Avatar
JR-01
I, too, change oil once a year if it needs it or not.
Old Nov 18, 2014 | 11:31 AM
Sinister-one's Avatar
Sinister-one
Only problem with this product is that you have to have an Amsoil account / membership. I did it for several years and came to find out with the shipping and disposal fees it's cheaper to just buy Mobil 1 or Castrol locally.
But don't get me wrong, Amsoil is a good product.
Old Nov 18, 2014 | 11:53 AM
JR-01's Avatar
JR-01
I was suggesting that he flush out his engine because his oil looked like crap. There are many products out there to do that. This was just one. For his oil I would go with Mobil1, too.
To Puny oil filter?
