Easy way to replace shift indicator
Old Nov 17, 2014 | 10:51 AM
rsl2715's Avatar
rsl2715
Default Easy way to replace shift indicator
Need help just ordered the kit to replacement automatic.Is there any easy way to install the kit??? Been driving for years with out it,but fixing everything now so it time for this, if not a total hassle.Help on how to do,or some place in the DFW area to have it done.R
Old Nov 17, 2014 | 06:50 PM
Mind sharing where you were able to find a kit to repair the red plastic piece on the shift indicator? All the posts I have read on this indicated that the red plastic piece was not sold as an individual item and you had to buy the entire shifter to fix it unless you could come up with some creative way to do it on your own.
(See the file below - it does not specifically cover replacement of the red indicator, but it does mention it as part of the replacement of the bulb inside the indicator).
Old Nov 17, 2014 | 10:57 PM
rsl2715's Avatar
rsl2715
Jack found at Factory OEM Parts $29.98 frees shipping" NEW Part"
They came up on EBay this is a real company not some guy selling.R
Old Nov 17, 2014 | 11:33 PM
ScumOne's Avatar
ScumOne
What search term did you use, or can you post the item # you are talking about? I need one for my 99 C5. Thanks!
Old Nov 17, 2014 | 11:56 PM
rsl2715's Avatar
rsl2715
The item nr is 281412932324 will fit all C-5 97-04.
Old Nov 18, 2014 | 03:21 AM
ScumOne's Avatar
ScumOne
Found it and bought one, thanks much!
To Easy way to replace shift indicator
