Hit a milestone tonite!
Old Nov 17, 2014 | 07:44 PM
ericdwong's Avatar
ericdwong
Default Hit a milestone tonite!
200k on my '98. Been my daily driver since New Years Eve of 2002. Never imagined keeping a car around for that long. Driven sun, rain, snow (with snow tires) and occasionally tows trailer for those home improvement projects
Original engine and trans, I've done all work/maintenance myself (except body work, alignment and tire mount/balance). Biggest failure was the slave cylinder crapping out requiring dropping the whole driveline on jackstands while I was at it, opened the trans and replaced some synchros.
We'll see how much longer she lasts
Old Nov 17, 2014 | 07:53 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Congrats, That is a milestone for sure.
Old Nov 17, 2014 | 07:55 PM
CQRT's Avatar
CQRT
congrats Eric - - quite a milestone.
Old Nov 17, 2014 | 08:45 PM
57gman's Avatar
57gman
That's fantastic, what oil do you use?
Old Nov 17, 2014 | 08:55 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Old Nov 17, 2014 | 09:03 PM
Donutz's Avatar
Donutz
Wow!!! Awesome!!!
Old Nov 17, 2014 | 09:06 PM
ericdwong's Avatar
ericdwong
Mobil 1 5W30 of course with AC Delco PF46 filters, changed when the DIC says so. Next oil change I'm going to have a Blackstone analysis done. Otherwise, uses no noticeable oil. Somehow the starter and alternator are still original. Replaced the water pump once. Hope I didn't just jinx myself
Old Nov 17, 2014 | 09:08 PM
donald4972's Avatar
donald4972
St. Jude Donor '14-'15
Very cool!!! Congratulations.
Plan to join you in the high mileage C5 club, someday.
Don
Old Nov 17, 2014 | 09:14 PM
ssrallyred's Avatar
ssrallyred
Awesome !! Congrats
Old Nov 17, 2014 | 09:50 PM
2FAS4UU's Avatar
2FAS4UU
Hope I have the same results with my 99', Good deal !!!
Crap !! your oil pressure gage still works !!!!!
Old Nov 17, 2014 | 09:53 PM
Grim Reaper's Avatar
Grim Reaper
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19
Old Nov 17, 2014 | 10:18 PM
Mickeyrx70's Avatar
Mickeyrx70
Congratulations! Glad to see you reach the milestone.
Old Nov 17, 2014 | 10:29 PM
Barndog Buddha's Avatar
Barndog Buddha
From: Gurnee IL. so close to Wisc. I can smell it when they cut the cheese
Fantastic! I wish you a couple hundred thousand more.
Old Nov 17, 2014 | 10:40 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Old Nov 17, 2014 | 11:08 PM
EBZ0602's Avatar
EBZ0602
2015 C5 of the Year Finalist
St. Jude Donor '05-'10
Outstanding!!& Congratulations on 200XXX!!!!!
Old Nov 17, 2014 | 11:35 PM
roadbike56's Avatar
roadbike56
St. Jude Donor '16-'17,'22,'24
Congrats, that's a great achievment.
Question, did you have to replace the ebcm or any other electonic modules or did it make it with all the original electronic equipment?
Old Nov 17, 2014 | 11:51 PM
ericdwong's Avatar
ericdwong
Nope (knocks wood), no replacement, original ECBM and all other modules. Also a TP sensor is dead but that's cause its battery is depleted. Only weird electrical hiccup I have is if I put the key in with the door closed the passenger mirror always readjusts itself. I'm aware of the memory thing apparently it's a bug somewhere. I've gotten used to inserting the key with the door open to prevent that...
To Hit a milestone tonite!
Old Nov 17, 2014 | 11:53 PM
ericdwong's Avatar
ericdwong
the oil pressure sensor was replaced once, probably 10 years ago with an aftermarket one. I used to get "LOW FUEL" too, but haven't seen that in 10+ years either.
Congrats on hitting 200K miles. Also good to hear that the car has not had a lot of problems in all those miles.
Old Nov 18, 2014 | 12:43 AM
VETJAZZ's Avatar
VETJAZZ
That's great! Congrats and here's to another 200K.
