Shifter Boot Ring woes
Old Nov 22, 2014 | 06:23 PM
blackmachdown's Avatar
blackmachdown
Default Shifter Boot Ring woes
So my 2001 Z06 has a pristine shifter boot ring, however the 97 I purchased did not!
As you can see its absolutely worthless...
I ended up looking for used ones on eBay, but found this instead
for the price I figured why not try it. Install was super easy and I think it looks great! My original boot though...needs some help!
All in all I am very happy and this is IMO a great alternative to the crappy boot ring that breaks super easy.
Old Nov 22, 2014 | 09:07 PM
The metal ring you bought is what GM should have installed on the car in the first place. It certainly would have been less likely to break like the plastic one.
Old Nov 23, 2014 | 06:41 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
I repaired the plastic ring with a little 5 minute epoxy and a couple pieces of plastic I cut out of a plastic dish I got from Olive Garden that was used for take out orders. It's good as new now. and been working for a couple years now with numerous removals.
Old Nov 23, 2014 | 07:02 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
If all the plastic parts were replaced with metal ones, the car would have cost 2 grand more.. and would have added 500 lbs.. on another note.. My shift boot ring has been in and out a dozen times, and still works as new... looks good as new too.
Old Nov 23, 2014 | 07:09 PM
Evil-Twin's Avatar
Evil-Twin
This is what draws the inner engineer out of many.
Its always nice to fix a problem using around the house parts that cost nothing..it gives you a sense of accomplishment, and in many cases make the part even stronger.
Nice work
Bill aka ET
AS I've said 1524 times over the last 13 years here is : If the C5 was perfect, none of us would be able to afford it.
I was shot down by my project manager for a revision that would have cost 0.07 cents per copy ( with seven parts per unit, it would have added 0.49 cents to the cost to manufacture. ) The rev did nothing to reduce weight, so the chances were slim to get it passed, but would have made a nicer looking part.
Bill aka ET
Old Nov 24, 2014 | 11:01 AM
dadaroo's Avatar
dadaroo
Well said Bill. Mr. Sam P.E.
Old Nov 24, 2014 | 11:11 AM
66dts-v's Avatar
66dts-v
Mine is busted to hell, I'll have to check this out, thanks.
<edit> I'm not finding it. Does a vendor have one like this?
Old Nov 24, 2014 | 11:53 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Last time I saw one of those, it was being marketed by 'Southern Car Parts'.....
Old Nov 24, 2014 | 03:11 PM
blackmachdown
I sent you a pm
Old Sep 22, 2016 | 04:14 PM
tommypenguin's Avatar
tommypenguin
Just discovered this thread, thanks for the heads up ralph. Had to order this today as my shifter ring is bombed out and depleted.
To Shifter Boot Ring woes
