Tire pressure for winter storage
Well I guess you are consistant in trying to find "inconsistency" in everything ET says ...many CF members including myself have followed what Bill has said over and over about tire pressure and benefitted greatly in our Vette performance, gas mileage and tire wear. Can't imagine why a bunch of numnuts here keep disagreeing with an engineer who actually helped develop some of the systems in the C5 and had first hand knowledge of the rest of the systems of the C5 Corvette...it amazes me that some shade tree wannabe mechanics in here would even want to argue with him...
anyway...carry on ET...
p.s....air molecules can and do escape through tire rubber...whoever disagrees is a flogging moron
Consider a cubic foot of air... in that cubic foot of air, are millions of Oxygen and Nitrogen atoms.. some argon and hydrogen which makes moisture... ( H2O ) when the ambient temp is cold, the space between the molecule shrinks.. allowing more Nitrogen and Oxygen atoms to occupy the same space... this Cold ambient temp condition is mother natures super charger... it compresses the volume so the more oxygen can be added to the fuel misture withing the same volume. this is why you lose HP in hot weather, and get an increase in HP when its cold... Corrected dyno numbers use a correction factor od 1.8 Hp per ten degrees. so a decrease in temp from 90 degrees F to 20 degrees F. can yield a 12.5 hp gain in the winter over the summer at 90 F.
Back to the tires... I have said for many years you test your tire pressure when they are hot ( at operating temp ). this is the pressure they see when actually working.. this actual temp effects how the foot print reacts to driving conditions.. Its what NASCAR and Most Road course pit crews use to set their tire pressure.. IN a 500 mile race, track temps can vary by as much as 80 degrees.
IN a garage in Georgia on a cool cement floor in the morning ambient temps inside a tire at rest could be 50 degrees... now take that car out on a hot Georgia Blacktop on a 95+ day and the road temp can see 140 F at the surface.. that's a 90 degree variation.. a 30 PSI cold temp in the garage can easily see 38 psi when hot. that's too much pressure.
this is why you get poor performance and center wear on a tire that is overinflated.
I set my pressure for summer driving and for winter driving... in the winter in the North east. I set my in garage pressure to 32/34 psi so when they get out on a 20 degree roadway they are at 30 PSI
IN the summer when temps on the road can see 140.. I set my cold garage temps to 27/28 so they see 30 psi when they are actually performing.. Pit crews adjust tire pressure for actual performance and not for cold static non use.
BTW as I said, cold weather is Mother Natures supercharger compressing the air so more oxygen can get into the mix.. this is why your car seems to run better in the cold weather..
AS the air compresses that cubic foot of air increases its molecular structure because more air can occupy that same space, because its compressed. air is also compressed in cold weather in your tires that why you loose pressure in your tire, ( it doesn't leave the tire ) its just compressed.. when you add that 2 extra lbs of air to bring it back to 30 psi. that the amount of extra air you can add to the same space., More air in the fuel mix under the same flow rate will increase HP. ( the same principle used in a supercharger.
IM just offering a little automotive 101 here.. I really don't want to hear any more mentally challenge people dispute this fact. Take it or leave it.
I hope this will help some people understand the relationship between temperature and air pressure.. the ones that don't get it or don't believe it, I'm sorry.
Bill aka ET
Looks like its time for a basic physics refresher:
PV=nRT
where:
P is the pressure of the gas
V is the volume of the gas
n is the amount of substance of gas (also known as number of moles)
R is the ideal, or universal, gas constant, equal to the product of the Boltzmann constant and the Avogadro constant.
T is the temperature of the gas
In out case with tires, V, n and R are constants so it does not matter. Simply speaking, what remains are Temperature and Pressure.
Temperature and pressure are directly proportional to each other with nR being the scaling factor.
The only variable is the real leakage (valve stem, rims, etc) and the microscopic leakage (which scientifically does occur but is not really measurable).
Bottom line is that one should keep an eye on their car when in storage and give it the same TLC as if it were the summer months.
About to head off to storage
I decided to keep the tires at 30psi. I measured the pressure with a swanky new gauge with a round dial and it told me that I had only 25psi. So I got out my new Slime kit and ran the compressor only (no slime) until it told me I had 30psi. But at the outset it told me I had 28 or so, and I only added about 2 psi. Unsure of all of this, I went to the store that sold me the Hankooks and they measured the pressure using one of those stick-style gauges. It said I was right at 30 psi. That was fine until the next morning when, just starting on my trip to the storage unit, I check the TPMs using the gauges on the dash, and it said my tires were at 28psi. What gauge should I believe? By the time I got to the storage unit my wife was in a big hurry to turn around and get home, so there was no chance to put more air in the tires. So there are there for 4 months at either 28 or 30 psi. I'll let you know in April if it survived.
Sorry about all that white stuff but the car looks pretty sweet against the backdrop.
As I've said for 13 years here on the Forum since retiring from GM
" Be careful who you listen too about a C5, on this forum "... Even stupid has an opinion.
Bill aka ET
https://www.corvetteforum.com/forums...conflicts.html
For the time being this thread has gotten off track and is now closed for the time being.
Maybe giving vacations would be a better choice?
As far as being too serious and health issues.. well, many of my close friends here know how sick I am, and because I am so sick, I spend a lot of time here to take my mind off my very serious health issues.. Last year I was expected Not to be here this year... last years I spent 31 days in critical care, after surgery, being diagnosed with Cancer. IM not trying to create drama, here believe me, but as you can see IM here to help people,., and not be disrespected. So its the disrespect that drives the back and Forth.. Jim Willis ( savewave )knows of my health issues and told me that the moderators would be sensitive to personal attacks because with so many post , there are bound to be problems.. when the mods don't step in when people disrespect me.,.. I have to defend myself, and I will... so sorry for the drama...but I've invested thousands of hours here offering insider information on how this car was built.. things that you wont find in any book...and offering many hours of answering thousands and thousands of private message and open forum help questions.
