Best Lift for Storage
Thanx
If your going to pull the plug, don't go cheap. Highly recommend BendPac. In any case good,luck,and enjoy!
If your use is "Mostly" going to be storage and once in a while for working on the car, you will be best served by the four post lift.
RS
PS: I still get a chuckle from Mr. Bill's avatar.......lol.
Here's my BendPak HD9 (9000 lb. cap., 117" width):
In Indiana, it turned our 2-car into a 3-car
Here in SoCal now, our 3-car is a 4-car
Current project underway
Turned my 4 car garage into a 5 car.
Also, keep in mind that you can always get a rolling jack --- it's a pneumatic jack that can slide down the center, and, if you get two of them, can completely (and safely) lift the car off the lift for wheel work. Pricey, though well worth it if you want to work on your car.
what is the ceiling height in your garage ?
For the garage door is one that rolls up at the top of the opening with a motor on the side the best?
I have a Direct Lift 4 post. I've had it for over 4 years had it had performed flawlessly in that time.
Here's the clearance I had when I first installed the lift - no clearance. The door was hitting the posts.
The new door height.
The new side-mounted opener with battery backup
No problems with clearance now and I actually store the vette 4" higher than in the previous garage since the door is no longer the limiting height.
a few dumb questions: can one park a SUV underneath with the Vette on top? Can you lift them that high? And secondly, how feasible is it to turn a two-car into a four-car? During the winter I could have a '49 Dodge on the top of one and my C6 on the other. Underneath, my winter "beater" and the wife's SUV.
I appreciate all comments...if I'm going to build it, I want to build it right the first time.
Thx
Mike
I did some preliminary measuring. My ceiling height is 10' 2" at the doors and 10' at the back wall. Unfortunately, I'd be trying to stack my Corvette over (or below) a Lexus RX350. My 'vette is in storage out of state so I can't measure its height, but doing a little research I found a diagram of a C5 showing 47.5" of height. I doubt that was for a convertible, which may be a little different one way or the other. Can someone tell me the height of the 'vert?
The Lexus is a tad under 68" in height. Adding the two together, I get 115.5", or a mere 6.5" less than the full height of the garage at the door and 4.5" at the rear. The Bend Pak website indicates (if I read it correctly) that the lift operates in 4" increments. It appears that I'd have to be lucky or good to get the lift to the precise height each time to avoid having a car hit the ceiling. Is there a way to program these lifts to get to the exact height that you want each time? What is the thickness of the platform on which the elevated car sits? How much room do I need between the roof of the lower car and the bottom of the wheels of the elevated car?
Maybe I need to trade in the Lexus for something lower. That's a large cost, since I just bought the Lexus. Any suggestions?
A four-post lift can cost new roughly anywhere from $1500-$5000, depending on brand/features. Mine fell right in the middle with several options and custom paint color. (BendPaks were always blue and you had to special order a different color back then. Didn't match my color scheme, thus the black paint.)
With what many of us here spend on mods and for caring for these cars - I consider this a fairly minor expenditure compared with the overall I spend on my "hobby". It keeps me busy and out of trouble and is a huge, much-needed distraction from an otherwise stressful job so I think it's well worth it. Not only do I get a fourth parking spot, I also get a lift to make mods and maintenance much easier.
I've had this lift several years and, after realizing the benefits all this time, I will always have one as long as I am able.
Oh, and I live in SoCal now but originally bought this lift in Indiana to be able to park my dd Mustang GT in the garage in winter so I didn't have to scrape the snow and ice off my car early on cold, winter morning before sliding off to work. The other benefits were just icing on the cake.
Rich guy?
Enthusiast?
Our Indiana garage
