key fob
Old Dec 14, 2014 | 08:01 AM
jjc508520's Avatar
jjc508520
Default key fob
So I have it apart - and there are 2 sets of these spring-loaded fingers that come up from the battery and (are supposed to) contact some metal pads on the bottom side of the circuit board that includes the 4 buttons. Is it a lack of contact in this area that's the common problem? Who knows how long this thing sat around on the dealer shelf so I guess I'll throw a new battery in it while I'm at it....
Old Dec 14, 2014 | 09:50 AM
Don't seem to have any problems with my fobs - they are nearly 12 years old and the original batteries are still working just fine. I guess if you use the fobs a lot, then obviously the batteries or other internal parts will show more wear.
Old Dec 14, 2014 | 11:04 AM
57gman's Avatar
57gman
Default 97' vette
In my case....I have a '97 and have two fobs, one with the auto open/lock feature. If I don't use them enough I have to reprogram them. Which is easy and the instructions are in the owners manual.
Did you try that?
Old Dec 15, 2014 | 08:01 AM
jjc508520's Avatar
jjc508520
Thought all the C5's had the same kind of key fob - my bad
A new battery in the fob and a "re-synch" with the car solved the problem - thanks 57GMAN for the pointer!
To key fob
