well i have removed my climate control from my 99 coupe because the lights were so dim you could hardly see them at night. now i'd like to send it off to be repaired with original style bulbs . i'm sure some of you have had this done and i would like your input and the name /address of the one doing the repair. thanks for your help and advice. i considered white led but afraid the climate control panel would then be much brighter than the other lights in the car. again thanks..........
I can attest that re-soldering the chips is easy to do. I have never used a soldering gun and it worked well. The big issue is pulling the center console and part of the dash to get to the circuit boards. I was surprised at how small the circuit boards were. If you find the tutorial on this forum, it is a piece of cake.
