C5 key blanks?
Old Dec 14, 2014 | 08:31 PM
bigbob76's Avatar
bigbob76
Default C5 key blanks?
Wanted a key for my 2001 made but no blank was available. I had a key made for my 2011 Tacoma and I had the option of either a key with chip that would open the door and start the truck or a key without a chip just to unlock the door. I had hoped to do the same thing with my C5. Is the key blank a dealership item? Thanks, Bob
Old Dec 14, 2014 | 08:40 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Check with your local lock smiths, You can get them for just the door or door and start the car, You can also get them off eBay for like 10 bucks, But be sure you know your resistance code.
Old Dec 14, 2014 | 08:42 PM
frsr06's Avatar
frsr06
There are 15 different key blanks, each with a different resistor in it. You will either need to know which key you need by measuring the resistance in the chip or will have to go the dealer with your VIN to determine. Once you get the right key it can be cut anywhere.
There have been several recent posts with a chart of resistance vs. the key blank number.
See the post above from Mr. Bill.
Good luck.
Old Dec 14, 2014 | 09:08 PM
You should be able to just get a blank key to open the door from a key shop. As Mr.Bill stated, if you want one to do the door and ignition, a locksmith can help you out as long as they have the right resistance value of the chip.
Old Dec 14, 2014 | 09:17 PM
Chicago1's Avatar
Chicago1
ebay is where I got mine
Old Dec 14, 2014 | 09:28 PM
bigbob76's Avatar
bigbob76
Thanks for the timely responses. I went out to my truck and got my meter. I'm reading 372 ohms. Do you think I should assume that is close enough and buy a #1 blank? Bob
Edit: I just saw this, maybe I am a real knucklehead and don't understand decimal points, lol! Maybe I have a #10. I'm getting my meter back out.
VATS Code 1-15 Resistance Values:
1 = 400 ohm
2 = 525 ohm
3 = 680 ohm
4 = 885 ohm
5 = 1.13k ohm
6 = 1.465k ohm
7 = 1.86k ohm
8 = 2.36k ohm
9 = 3.02k ohm
10 = 3.73k ohm
11 = 4.75k ohm
12 = 6.05k ohm
13 = 7.5k ohm
14 = 9.54k ohm
15 = 11.79k ohm
Old Dec 14, 2014 | 10:14 PM
bigbob76's Avatar
bigbob76
Okay, also had an old battery in the meter. Now I see 3.705k ohms so I will get a #10 blank.
Old Dec 14, 2014 | 11:03 PM
bigbob76's Avatar
bigbob76
ordered for $6.50
http://www.clksupplies.com/shop/vats...-24_26_67.html
Old Dec 14, 2014 | 11:24 PM
Mr.Bill's Avatar
Mr.Bill
6.50 for the key is ok, I would rather have a GM key with the logo on it which these don't I believe. Also they are the small head keys.
Old Dec 14, 2014 | 11:44 PM
bigbob76's Avatar
bigbob76
On one of these keys I will be cutting the plastic off and trimming off most of the metal on the head of the key. I did this with my door key for my truck. I did the same with my house keys. I drilled a hole through all of them, put them together with a brass machine screw and nut. I cut off the excess machine screw and peened it with a hammer. I now have an extremely compact set of keys. They are mostly as back up/emergency or so I can leave my truck running and lock the doors while I go in a convenience store for coffee.
Old Dec 15, 2014 | 12:25 AM
bigbob76's Avatar
bigbob76
$6.50 for 2 keys.
Old Dec 15, 2014 | 01:22 AM
C5Natie's Avatar
C5Natie
Good info here. Thanks for the link. I can use an extra key or two.
To C5 key blanks?
