Drivers seatbelt receiver help!
Old Dec 15, 2014 | 07:58 PM
Jeremy Wells's Avatar
Jeremy Wells
Default Drivers seatbelt receiver help!
Im removing the seatbelt receivers on my stock seats and on the drivers side there is a cable, looks like from power seats in there. How do i get it out so i can attachbthese to my new seats?
Old Dec 15, 2014 | 08:09 PM
RedWhitefast's Avatar
RedWhitefast
If it's black there are two wires in it and the go to the micro switch for your seat belt light. Turn your old seat over and you'll see where the connection can be separated. Hope this helps
Old Dec 16, 2014 | 10:03 AM
bumble-z's Avatar
bumble-z
Remove the four nuts that hold down the seat rails.
Tip the front rails up & apply blocking under them.
This will give you plenty of room to disconnect the connector.
Put heavy blanket, towel, etc over the sills, as not to scratch them when you remove the seat.
To Drivers seatbelt receiver help!
