Been looking ata lotta early C5s and was leaning towards a stick, but lately am also considering an auto. question is what is the reliability of an automatic and how well do that hold up, thanx
The automatic on my 2003 had to be rebuilt at about 85,000 km (52,000 miles). People are telling me that is unusual. The transmission shop had no real explanation other than "bad luck". I am the third owner and the car seemed well cared for but you never know how previous owners treat them I guess.
IMO, a lot depends on how well the car is maintained and the driving habits of the owner. Constant harsh treatment, as with anything mechanical, can cause premature wear and breakage.
I'm guessing that you're using rather non-standard definitions for "always" and "early".
The large number of high-mileage C5s still on their original un-rebuilt transmission makes your statement either sarcastic or silly.
Usually they die around 100k miles give or take. My 2005 Sierra is on its third 4L60 and the second one was "built" by a local performance shop. Granted that truck is heavy and probably harder on a transmission than a 3200 pound corvette, but I come from the truck world where the 4l60 is regarded as junk.
The amount of torque management GM has to add to protect them during their 100k power train warranty says everything you need to know about the transmission. For what it is worth, my truck has 0% torque management.
Mine has been very reliable, close to 160,000 miles on it now, and it has been going to the track for over 6 years... hundreds and hundreds of track passes ( and it has stretched it's legs on the street for almost 10 years). No problems so far
My A4 got it's first fluid change at 74,000 miles when I bought the car.
Now at 97,000 miles, I've done 9 road course track days, over 700 miles at WOT or hard on the brakes.
I drive sedately on the street "most" of the time.
But I run Redline fluid and change it and filter every two years because of track use.
Because the A4 is challenging to keep cool on a road course track, I also have an extra capacity B&M finned aluminum transmission pan, a DeWitts aluminum radiator with integral trans cooler and an auxiliary transmission cooler with fluid thermostat.
I ran 600 HP through mine for several years until I went with an RPM level V. I drove it the way the car was meant to be driven and it never missed a beat. I only did the level V because I was in there doing a converter and 3:42. The trans looked like new and probably would have gone several more years.
