trunk interior lights...
Old Dec 22, 2014 | 11:29 AM
LBCZ06's Avatar
LBCZ06
5th Gear
Default trunk interior lights...
I have a 02 Z06 and the trunk area lights don't work... the rest of the interior lights work. Any ideas? Before I tear into it I thought id see if you guys know the short cut? is it a hidden connection somewhere?
Thanks!
Old Dec 22, 2014 | 11:33 AM
vettefan84's Avatar
vettefan84
Thanks!
Hi there...well did you check bulbs? You have to remove part of trunk carpet where these lights are located to get acces i replaced bulbs in mine 5 mins work....good luck....check bulbs
Old Dec 22, 2014 | 12:45 PM
LBCZ06's Avatar
LBCZ06
5th Gear
Give me some credit lol. Yeah, checked the bulbs and fuses.. Odd that the other lights work and not these...
Old Dec 22, 2014 | 01:42 PM
c5z06.O's Avatar
c5z06.O
Default illum. ****
Have you tried opening the trunk lid? J/K. The last post you made was funny.
Old Dec 22, 2014 | 02:06 PM
65GGvert's Avatar
65GGvert
When you do nothing else except pop the trunk, do the under dash courtesy lights come on (doors closed)?
Old Dec 22, 2014 | 02:15 PM
c4cruiser's Avatar
c4cruiser
Could be a bad connection or a ground problem. You may have to start removing the plastic trim and the carpeting and trace the wires back to plastic connectors. With both lights not working, it does sound like a wiring issue. It would help to have a digital volt meter to check for voltage at the connections.
To trunk interior lights...
